Kyocera FS-C8020MFP - multifunction ( printer / copier / scanner ) ( colour )
Quicklinx: 7WHJWS00 Mfr#: 1102KZ3NL0
The FS-C8020MFP is a 20ppm color network print/copy/scan device designed specifically for the smaller office environment. Featuring advanced functionality, easy to operate touch screen and a range of paper-handling options, all in a well designed compact package. Cost-efficient and eco-friendly offices will appreciate KYOCERA's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
  • Clever functionality with user-friendly instructions
    You need to print, fax and copy data in A4 and A3? No problem. Like to scan and share documents in color even if printing jobs are mainly done in black and white? At no extra cost? Also no problem. No more lost time on complex operations. No more frustrations trying to work out the best way to present your information. Simply scan your documents and send them directly to an individual PC, store them on a network server, or even attach to specific e-mail. Streamline your archiving by ensuring documents are stored and easily retrievable from where they belong.
  • The Smart MFP for a small office with a smaller budget
    KYOCERA's ECOSYS technology is where economy and ecology meet. This unique technology cuts the cost of consumables and energy use, as well as providing exceptionally low printing and whole-of-life costs. Long-life technology with longer maintenance cycles help ensure unprecedented reliability. The Smart Series has been designed to minimize ozone emissions and reduce noise levels, whilst promoting a more comfortable office environment.
  • Professional quality full-color printing
    Together with A3 printing, this multifunctional printer offers full, professional print quality and functionality. The improved toner technology and superior hardware of the FS-C8020MFP deliver vibrant, high resolution color printing, ensuring pin-sharp lines and clear images. It is a smart choice for eco-friendly offices - when the toner does finally run out, it is only the toner container that needs to be replaced, instead of an entire cartridge including drum and/or developer.
  • Keeps your information, documents and data secure
    As data security becomes a high priority, this Smart Series multifunctional printer meets security standards required in modern corporate network environments. The printer is easily integrated into your company's IT infrastructure and comes with an IPsec and the SSL suite of encryption protocols, ensuring data traveling through your network is secured. The Active Directory network authentication enhances security without the need to set ID access data for each single user.
  • Functionality to fit your compact, well-designed office
    The FS-C8020MFP is designed with compact offices in mind. Its 360° all-round style looks good from any direction, even in the middle of the office! This machine can even be fine tuned to suit your unique work requirements, due to its compact design. This A4 and A3 printer provides big support in any small office.
  • Status Monitor and Command Center
    The Status Monitor shows the current printers condition and gives direct access to the Command Center for the modification of settings that are not contained in the drivers (e.g. network settings, adjustment of sleep mode or blocking of the control panel).
  • USB host interface for USB flash memory
    PDF files can be printed directly from a USB flash memory via the USB host interface. Documents are selected directly via the printer's control panel. No computer is required.
  • PRESCRIBE
    With the KYOCERA page design and control language PRESCRIBE, even complex graphics, logos and forms can be created independently on the system and saved and updated in the printer.
Kyocera FS-C8020MFP - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Max Copying Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Scanning
600 x 600 dpi
Display
4.3"
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
280 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V (50/60Hz)
59 cm x 59 cm x 74.8 cm
80 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
Display Diagonal Size
4.3"
Display Features
Touch screen
Standard Memory
1 GB 1 GB
Max Supported Memory
2 GB 2 GB
Copying
Max Copying Speed
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, KPDL3, PDF, XPS
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
14 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3/Ledger
Min Media Weight
45 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), Folio (216 x 330 mm)
600 sheets
Max Media Capacity
1600 sheets
100 sheets
280 sheets
Paper cassette - 500 sheets - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 256 g/m² , ADF - 50 sheets - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 30 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Copying: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple MacOS X 10.2 or later, MS Windows Vista
AC 230 V (50/60Hz)
Warm-Up Time
50 sec
First Copy Out Time B/W
12.7 sec
First Copy Out Time Colour
15.6 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
Supported Windows 7 Features
Windows HD Imaging
TUV GS, C-Tick, ISO 9001, ISO 14001
ENERGY STAR Certified
59 cm
59 cm
74.8 cm
80 kg
