Kyocera FS-C5400DN Colour Printer
Quicklinx: 6CMCWS00 Mfr#: 1102HG3EU0
The FS-C5400DN Kyocera ECOSYS color printer delivers the exceptional color output, high performance, and low total cost of ownership that today's cost conscious businesses demand. With its high speed duplex productivity and wide media flexibility, the FS-C5400DN will let you print more color documents in house allowing for fast on demand production, saving outsourcing costs, and improving turn around times. Through Kyocera's advanced technology, energy use has been reduced and most replacement parts have been eliminated or replaced with long life components, reducing downtime and maintenance requirements. And unlike competitive products, the FS-C5400DN offers efficient performance without excessive costs for supplies and service.
  • Efficient printing speed
    Achieve remarkable printing speeds of up to 35 ppm in both black and white and color, ensuring your documents are ready when you need them.
  • Advanced media handling
    Supports a wide range of media sizes from A6 to Legal and weights from 60 g/m2 to 220 g/m2, making it versatile for all your printing needs.
  • Eco-friendly technology
    Incorporates Kyocera ECOSYS Technology, designed for durability and long-life components, reducing waste and operating costs.
  • High-capacity printing
    With a maximum media capacity of 2650 sheets and automatic duplexing, handle large print jobs efficiently and reduce paper usage.
  • Comprehensive connectivity
    Offers multiple connectivity options including LAN, USB, and USB host, ensuring easy integration into your existing network.
Kyocera FS-C5400DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
35 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 dpi
Max Resolution (Colour)
9600 dpi
Automatic Duplexing
USB, LAN, USB host
RAM Installed (Max)
256 MB (1.25 GB)
Language Simulation
PCL 5C, PCL 6, KPDL3, PDF, PRESCRIBE IIe, XPS
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
650 sheets
Media Handling
150-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
20000 pages
Print server - Ethernet, Fast Ethernet
Printer Features
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later
Microsoft Certification
Compatible with Windows 7
2-year warranty (Italy - 2 years with product registration)
34.5 cm x 51.8 cm x 51.2 cm
Printer Type
Printer
Print Speed
Wired
USB, LAN, USB host
9600 dpi
9600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8 sec
First Print Out Time Colour
9 sec
Language Simulation
Fonts Included
93 x PCL , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
256 MB / 1.25 GB (max)
Slots Qty
1
Empty Slots
1
Card Reader
Supported Flash Memory Cards
CompactFlash Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
650 sheets
Media Feeders
1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
2650 sheets
Output Trays Capacity
500 sheets
Duty Cycle
150000 pages
20000 pages
Print server
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP 3
Security Protocols & Features
SSL, IPsec, 802.1x
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
Supported Windows 7 Features
Windows HD Imaging
TUV GS, ISO 9001, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
608 Watt
Regional Warranty Exceptions
Sound Emission (Idle)
36 dBA
Sound Emission (Operating)
55 dBA
34.5 cm
51.8 cm
51.2 cm
35 kg
