Professional office color is provided by the FS-C5150DN for demanding users and small office teams. This compact color printer saves your office space and fits perfectly in any office environment due to its low noise emissions. It convinces with reduced power consumption, lower emissions and less waste as well as with its integrated duplex unit for double-sided printing. The FS-C5150DN is not only an excellent business decision, it's an excellent choice for the environment, too.
Efficient productivity
With a robust monthly duty cycle of 50,000 pages and recommended monthly volume of 2,800 pages, this printer is designed to handle the workload of busy office environments efficiently. -
High-quality printing
Boasting a maximum resolution of 9600 x 600 DPI for both black and white and color prints, the Kyocera FS C5150DN ensures sharp, vivid outputs for all your documents and graphics. -
Eco-friendly design
Incorporating Kyocera ECOSYS Technology, this printer not only offers long-term reliability and high-quality prints but also emphasizes environmental sustainability through its energy-efficient performance. -
Versatile media handling
Supports a wide range of media sizes from A6 to Legal and weights from 60 g/m2 to 220 g/m2, accommodating various printing needs with ease. The duplex printing feature further enhances its versatility. -
Advanced connectivity
Equipped with Ethernet and USB interfaces, including direct print USB, the printer offers flexible connectivity options for seamless integration into any office network.
- Kyocera FS-C5150DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 29.3 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 21 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB, LAN, USB host
- Processor
- PowerPC 464 H90 667 MHz
- RAM Installed (Max)
- 256 MB (1.25 GB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, PRESCRIBE IIe, XPS
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 2800 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty (Italy - 2 years with product registration)
- 39 cm x 52.3 cm x 37 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 10.5 sec
- First Print Out Time Colour
- 12 sec
- Fonts Included
- 93 x scalable PCL , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 256 MB / 1.25 GB (max)
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- Media Thickness Range
- Up to 0.11 mm
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Max Media Capacity
- 1300 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 50000 pages
- 2800 pages
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
- Supported Windows 7 Features
- Windows HD Imaging
- TUV GS, ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 360 Watt
- Power Consumption Stand by / Sleep
- 57 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Regional Warranty Exceptions
- Italy - 2 years with product registration
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 50 dBA
- 39 cm
- 52.3 cm
- 37 cm
- 29.3 kg
