Wonderfully fast and reliable, the FS-9530DN printer also comes with a highly functional modular design that large departments need to get the entire job done. And with a print speed of 51 pages per minute in A4, the Kyocera FS-9530DN can handle large print volumes quickly and professionally.
Efficient printing speed
With a printing speed of up to 51 ppm for A4 and 26 ppm for A3 documents, this workgroup printer ensures your work flows smoothly and efficiently, reducing wait times and increasing productivity. -
Advanced connectivity options
Equipped with Ethernet, USB, and parallel interfaces, this printer offers versatile connectivity options, making it easy to integrate into any office environment and allowing multiple users to connect seamlessly. -
High-resolution output
Kyocera Image Refinement 2 technology alongside a maximum resolution of 1800 x 600 DPI delivers sharp, clear, and professional monochrome prints, ensuring your documents always look their best. -
Generous media handling
A total media capacity of 1200 sheets, supported by a 200-sheet multipurpose tray and two 500-sheet input trays, accommodates a wide range of media sizes and types, from plain and recycled paper to labels and foil paper, offering the flexibility your office needs. -
Eco-friendly design
ENERGY STAR certified, this printer meets strict energy efficiency guidelines, making it an environmentally friendly choice for your office without compromising on performance or productivity.
- Kyocera FS-9530DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 68 kg
- Media Size Class
- A3/Ledger
- Max Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
- Max Media Size (Custom)
- 297 mm x 450 mm
- Print Speed
- Up to 51 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - B/W - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1800 x 600 dpi
- Image Enhancement Technology
- Kyocera Image Refinement 2
- Automatic Duplexing
- Interface
- Parallel, USB, LAN
- Processor
- PowerPC 750FL 600 MHz
- RAM Installed (Max)
- 128 MB (640 MB) - DDR SDRAM - DIMM 100-PIN
- Card Reader
- Language Simulation
- PostScript 3, PCL 6, EPSON LQ, Diablo 630, KPDL3, KC-GL, PDF, PRESCRIBE IIe, IBM ProPrinter X24e
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Labels, plain paper, foil paper, recycled paper
- Total Media Capacity
- 1200 sheets
- Media Handling
- 2x 500-sheet input trays, 200-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 300000 pages
- Recommended Monthly Volume
- 55000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later, Apple MacOS 9.x or later
- Microsoft Certification
- Certified for Windows Vista
- 59.9 cm x 64.6 cm x 61.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1800 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 3.5 sec
- Fonts Included
- 136 x PostScript 3 , 80 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Media Handling
- Processor
RAM
- 128 MB / 640 MB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 297 mm x 450 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 450 mm, 88 x 148 mm
- Media Weight
- 45 g/m² - 200 g/m²
- 1200 sheets
- Media Feeders
- 1 x automatic - 200 sheets - 297 x 450 mm weight: 45 g/m² - 200 g/m² , 2 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 105 g/m²
- Max Media Capacity
- 4200 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 300000 pages
- 55000 pages
- Networking
- Print server
- Data Link Protocol
- Expansion Bays
- 1 (total) / 1 (free) x internal
- Expansion Slots
- 1 x CompactFlash Card
- Connections
- 1 x LAN - RJ-45 , 1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- TUV, ISO 9001, GS, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 900 Watt
- Power Consumption Stand by / Sleep
- 180 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 56 dBA
- 59.9 cm
- 64.6 cm
- 61.5 cm
- 68 kg
