With a print speed of 40 pages per minute in A4, the Kyocera FS-9130DN is ready to carry you through the heaviest of loads without slowing down. Fast, efficient and reliable, this printer also has a highly functional modular design. The paper and finishing options make it easy to fit the printer to your department's precise needs.
Reliability
The FS-9130DN is certified highly reliable by BLI, completing a 100000 impression durability test with just on misfeed and no service of any kind required. Furthermore, the unit went on to produce another 100000 impressions over the course of toner yield testing with no failures. -
Easy of network setup
Setup and installation of the drivers was easy thanks to the auto install feature, which automatically crates the port and will have users up an running in minutes. Although installation of the KX driver requires 12 clicks of the mouse because the drivers are combines, users need only install one. -
Print productivity
Using the KPDL driver to produce BLI's 19-page job stream, which replicates typical office usage in a multi-user environment, the FS-9130DN's efficiency of 65.4 percent of its rated engine speed is well above average compared to ledger-size laser/LED devices tested to date. -
Easy of use
The FS-9130DN's control panel is well designed and easy to use, featuring a two-line, 32-character LCD and eight LEDs for ready, attention, finisher, drawer one, drawer two, drawer three and bypass. -
Security features
Secure print allows a user to send a print job directly to the FS-9130DN and hold it until it is release via the control panel. After it is printed the unit deletes the job from memory. Administrators can lock the control panel via the embedded web page. -
Value
The FS-9130DN's supplies cost per page is the lowest compared to ledger-size laser/LED devices in this speed range tested to date. In fact, it is just over 80 percent lower than the average. This much lower cost per page translates to a substantial cost saving over competitive devices throughout its lifetime.
- Kyocera FS-9130DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 68 kg
- Media Size Class
- A3/Ledger
- Max Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
- Max Media Size (Custom)
- 297 mm x 450 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - B/W - A3 (297 x 420 mm) , Up to 33 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 16 ppm - B/W duplex - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1800 x 600 dpi
- Image Enhancement Technology
- Kyocera Image Refinement 2
- Automatic Duplexing
- Interface
- Parallel, USB, LAN, USB host
- Processor
- PowerPC 750FL 600 MHz
- RAM Installed (Max)
- 64 MB (576 MB) - DDR SDRAM - DIMM 100-PIN
- Card Reader
- Language Simulation
- PostScript 3, PCL 6, EPSON LQ, Diablo 630, KPDL3, KC-GL, PDF, PRESCRIBE IIe, IBM ProPrinter X24e
- Barcodes
- PDF417
- Media Type
- Labels, plain paper, foil paper, recycled paper
- Total Media Capacity
- 1200 sheets
- Media Handling
- 2x 500-sheet input trays, 200-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 180000 pages
- Recommended Monthly Volume
- 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later, Apple MacOS 9.x or later
- Microsoft Certification
- Certified for Windows Vista
- (France - 1 year)
- 59.9 cm x 64.6 cm x 61.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1800 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 3.5 sec
- Fonts Included
- 136 x PostScript 3 , 80 x PCL , 1 x bitmapped , 45 x barcode
- Barcodes
- PDF417
- Media Handling
- Processor
RAM
- 64 MB / 576 MB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 297 mm x 450 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 450 mm, 88 x 148 mm
- Media Weight
- 45 g/m² - 200 g/m²
- 1200 sheets
- Media Feeders
- 1 x automatic - 200 sheets - 297 x 450 mm weight: 45 g/m² - 200 g/m² , 2 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 105 g/m²
- Max Media Capacity
- 4200 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 180000 pages
- 20000 pages
- Networking
- Print server
- Data Link Protocol
- Expansion Bays
- 1 (total) / 1 (free) x internal
- Expansion Slots
- 1 x CompactFlash Card
- Connections
- 1 x LAN - RJ-45 , 1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- TUV, ISO 9001, GS, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 710 Watt
- Power Consumption Stand by / Sleep
- 160 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Regional Warranty Exceptions
- France - 1 year
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 56 dBA
- 59.9 cm
- 64.6 cm
- 61.5 cm
- 68 kg
Kyocera Toner Kit TK-710 | In Stock | £142.27 |
