This multifunctional device offers all the benefits of a professional document management solution for workgroups and small offices. Cost-efficient and Eco-friendly offices will appreciate Kyocera's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
Efficient connectivity
With options for Gigabit Ethernet, USB 2.0, and USB host, the Kyocera FS-6525MFP ensures seamless integration into any office network, facilitating easy sharing and management of documents. -
High-quality copying
Achieve crisp, clear copies at speeds of up to 25 pages per minute with a maximum copying resolution of 600 x 600 DPI. Automatic duplexing and the ability to handle up to 999 copies make it ideal for high-volume tasks. -
Versatile document handling
From the 50-sheet Automatic Document Feeder (ADF) to the 1600-sheet maximum media capacity, this device is equipped to handle diverse printing needs, supporting media weights up to 256 g/m2 for high-quality output on various paper types. -
Advanced printing technology
Leverage the power of laser printing with automatic duplexing to produce monochrome documents at 25 ppm. Compatibility with PCL 6, PDF, PostScript 3, and XPS ensures wide-ranging support for different document types. -
Comprehensive scanning capabilities
The FS-6525MFP offers an optical resolution of 600 DPI for scanning, complemented by features like save to USB, scan to email, and scan to network, enhancing office productivity and document workflow.
- Kyocera FS-6525MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 25 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 25 ppm
- Max Printing Resolution
- Scanning
- 600 dpi
- Original Size
- 140 x 182 mm (min) - A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 59 cm x 59 cm x 69.4 cm
- 52.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty (France - 1 year)
- Copier Type
- Digital
- Laser - monochrome
- Interface
- Standard Memory
- 1 GB 1 GB
- Max Supported Memory
- 2 GB 2 GB
- Supported Flash Memory
- CompactFlash
Copying
- Max Copying Speed
- Up to 25 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 25 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, KPDL3, PDF, XPS
- First Print Out Time B/W
- 8 sec
Scanning
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
Document & Media Handling
- Min Original Size
- 140 x 182 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 45 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), 297 x 432 mm, 140 x 182 mm, 98 x 148 mm
- 600 sheets
- 1600 sheets
- 100 sheets
- 300 sheets
- Input tray - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 50 sheets
- Speed Details
- Printing: up to 25 ppm (A4) - B/W , Printing: up to 12 ppm (A3) - B/W , Copying: up to 25 ppm (A4) - B/W , Copying: up to 12 ppm (A3) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 20 ipm (A4) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP, IPX/SPX, AppleTalk, NetBEUI, HTTPS, IPv4, IPv6
- Kerberos, SSL, IPsec, 802.1x
- Operating System Support
- UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
- Voltage Required
- 530 Watt
- Power Consumption Standby
- 114 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 20 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages
- TUV, ISO 9001, GS, ISO 14001
- ENERGY STAR Certified
- Limited warranty - 2 years , France: limited warranty - 1 year
- 59 cm
- 59 cm
- 69.4 cm
- 52.2 kg
- Sound Emission
- 27.1 dBA (idle) / 46.8 dBA (operating)
