Duplex printing, network connectivity and fax features allow the Kyocera FS-1325MFP to meet the demands of small offices and workgroups. With print speeds of 25 ppm in B/W and toner yields of 2100 pages this multifunctional easily scales up to handle bigger workloads. Its long life components significantly reduce running costs and environmental impact.
- Kyocera FS-1325MFP - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 25 ppm
- Max Printing Resolution
- Up to 1800 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR
- Scanning
- 600 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- Power
- AC 230 V (50/60Hz)
- 39 cm x 36.1 cm x 36.2 cm
- 10.1 kg
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0, LAN
- Standard Memory
- 64 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 25 ppm
- Printer Drivers / Emulations
- Windows GDI driver
- First Print Out Time B/W
- 7.5 sec
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 40 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 40 sheets - 216 x 356 mm , Output tray - 100 sheets , Bypass tray - 1 sheet size: 70 x 148 mm - 216 x 356 mm weight: 60 g/m² - 220 g/m²
- Speed Details
- Printing: up to 25 ppm (A4) - B/W , Scanning: up to 18 ipm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8
- Voltage Required
- 355 Watt
- Power Consumption Standby
- 8 Watt
- Power Consumption Sleep
- 4 Watt
- Warm-Up Time
- 28 sec
- First Copy Out Time B/W
- 13 sec
- TUV GS
- Limited warranty - 1 year - carry-in
- 39 cm
- 36.1 cm
- 36.2 cm
- 10.1 kg
Kyocera TK-1125 Black Toner Cartridge 2.1k Yield | In Stock | £45.84 |
