Get the job done, professionally and economically, with the FS-1120D that fits the needs of small offices and businesses. This compact, yet fast desktop monochrome laser printer provides users with up to 30 pages per minute, paper saving two-sided duplex printing, and connects easily to any PC with a standard USB interface. The FS-1120D is a robust and reliable printer with Kyocera's proven ECOSYS long-life technology, with a cartridge-free design and durable components, making this printer an economical sound investment.
PRESCRIBE IIe
With the Kyocera page design and control language PRESCRIBE IIe, even complex graphics, logos and forms (multipart forms) can be created independently on the system and saved and updated in the printer. Consequently, integration into print files no longer applies. They are only accessed as required and therefore relieve the load on the network. -
The KM NetViewer
The KM NetViewer enables complete monitoring and control of all ECOSYS printers and digital Kyocera multifunction units from any Windows PC and thus provides ideal network administration. It also supports the standardized SNMP protocol. -
Status monitor and command center
The status monitor shows the current printer's condition and gives direct access to the command center for the modification of settings that are not contained in the drivers (e.g. network settings, adjustment of sleep mode or blocking of the control panel).
- Kyocera FS-1120D - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 12 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Kyocera Image Refinement
- Automatic Duplexing
- Interface
- USB
- Processor
- PowerPC 405F5 360 MHz
- RAM Installed (Max)
- 32 MB (544 MB)
- Card Reader
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, Diablo 630, KPDL3, IBM ProPrinter X24, PRESCRIBE IIe, EPSON LQ 850
- Barcodes
- PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 50-sheet multipurpose tray, 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 2800 pages
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty (Italy - 2 years with product registration)
- 37.5 cm x 39.3 cm x 25 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- Fonts Included
- 1 x bitmapped , 45 x barcode , 80 x outline
- Barcodes
- PDF417
- Printer Features
- Media Handling
- Processor
RAM
- 32 MB / 544 MB (max)
- Slots Qty
- 1
- Empty Slots
- 1
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 50000 pages
- 2800 pages
- Expansion Slots
- 1 x KUIO-LV
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- TUV GS, ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 524 Watt
- Power Consumption Stand by / Sleep
- 7.3 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years
- Regional Warranty Exceptions
- Italy - 2 years with product registration
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 54 dBA
- Sound Emission (Quiet Mode)
- 49 dBA
- 37.5 cm
- 39.3 cm
- 25 cm
- 12 kg
