The professional standard functionalities of these compact A4 MFPs will increase the productivity of any office work group: with print and copy speeds of up to 30 pages per minute and a fast time to first print of only 6 seconds. Featuring a largecapacity document processor that scans double-sided originals for an enhanced document workflow. The clear structured five-line LCD display offers fast and easy access to all the functionality you need.
- Kyocera FS-1030MFP - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 impressions
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Up to 1800 x 600 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 49.4 cm x 41 cm x 36.6 cm
- 15 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty (Italy - 2 years with product registration)
- Copier Type
- Digital
- Laser - monochrome
- 20000 impressions
- Display
- 5 lines
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 768 MB 768 MB
Copying
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 30 ppm
- Printer Drivers / Emulations
- PCL 6, KPDL3, PDF, XPS, Diablo 630, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- 300 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- IPP, SNMP, IPv6
- SSL, IPsec
- Operating System Support
- UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 78 Watt
- Power Consumption Sleep
- 7.8 Watt
- Warm-Up Time
- 20 sec
- First Copy Out Time B/W
- 6.9 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages
- Supported Windows 7 Features
- Windows HD Imaging
- TUV GS, ISO 9001, ISO 14001
- ENERGY STAR Certified
- Limited warranty - 1 year
- Regional Warranty Exceptions
- Italy - 2 years with product registration
- 49.4 cm
- 41 cm
- 36.6 cm
- 15 kg
- Sound Emission
- 30 dBA (idle) / 54 dBA (operating)
