Efficient connectivity
With interfaces for Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for seamless mobile printing, this printer offers versatile connectivity options for any office environment. -
High-capacity printing
Boasting a maximum media capacity of 2100 sheets and supporting a wide range of media sizes from A4 to Legal, the Kyocera ECOSYS P7240cdn is designed to handle large print jobs with ease, making it suitable for busy workgroups. -
Superior print quality
Achieve high print quality with resolutions up to 1200 x 1200 DPI for both black and white and color documents, ensuring crisp, clear, and vibrant outputs every time. -
Rapid output speeds
Experience efficiency with first print out times as fast as 5.5 seconds for black and white and 6.5 seconds for color, enabling you to get your documents printed quickly without sacrificing quality. -
Eco-friendly technology
Leveraging Kyocera ECOSYS Technology, this printer not only delivers reliable performance but also promotes environmental sustainability with lower power consumption and a durable design that reduces waste.
- Kyocera ECOSYS P7240cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 31 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - colour - A4 (210 x 297 mm) , Up to 36 ppm - duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- Cortex-A9 1.2 GHz
- RAM Installed (Max)
- 1 GB (3 GB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PRESCRIBE IIc, PDF Direct
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- 39 cm x 53.2 cm x 46.95 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5.5 sec
- First Print Out Time Colour
- 6.5 sec
- Printer Features
- Media Handling
- Processor
- Cortex-A9 1.2 GHz
RAM
- 1 GB / 3 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 500 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 8000 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 641 Watt
- Power Consumption Stand by
- 77 Watt
- Power Consumption Sleep
- 0.6 Watt
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 53.5 dBA
- 39 cm
- 53.2 cm
- 46.95 cm
- 31 kg
