With an astoundingly high print speed and extraordinary low cost per page, this productive printer knows how to impress. Its amorphous silicon drum has an extremely long lifetime and makes it an exceptionally economical device. Additionally, it can be equipped with a total of five paper trays – supporting flexible paper handling and long print runs.
Key Features:
- Higher print speed (40ppm).
- Enhanced printer solution capability.
- 5 line LCD display and alphanumeric keypad.
- Optional card reader support.
- FollowMe print support in conjunction with KYOCERA Net Manager.
- Up to 2,100 sheet paper input via 5 trays.
- Mobile print support including KYOCERA Mobile Print and Mopria certified for iOS and Android devices.
- Apple Airprint and Google Cloud Print support.
- Three tier billing supported.
- Highly secure with SSL, IPsec and Private Print functionality.
- Support of optional IB-50 and IB-51 for network and wireless printing.
- Additional SD and SSD memory.
- Long-life aSi drum for 300,000 pages.
- Highest capacity toner boxes (12K colour and 16K black) for the lowest TCO in the range.
Efficient connectivity
With interfaces for Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for seamless mobile printing, this printer offers versatile connectivity options for both wired and wireless networking. -
High-quality printing
Leveraging advanced laser technology, the Kyocera ECOSYS P7040cdn delivers vibrant color and B/W printing with a maximum resolution of 9600 x 600 DPI, ensuring crisp and clear documents. -
Eco-friendly design
Certified by ENERGY STAR, the printer is designed for energy efficiency, consuming only 2.1 W in sleep mode and featuring Kyocera's ECOSYS Technology for sustainable printing solutions. -
Robust media handling
Supports a wide range of media sizes and types, including A4, Legal, and plain paper, with a total media capacity of 600 sheets, making it suitable for various printing needs. -
Secure and reliable
Equipped with HTTPS, IPsec, and SSL for secure data transmission, along with SNMP 3 for efficient remote management, ensuring your documents remain confidential and protected.
- Kyocera ECOSYS P7040cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 30.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- PowerPC 465S 1 GHz
- RAM Installed (Max)
- 512 MB (2 GB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PDF 1.7, PRESCRIBE IIc
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- 39 cm x 53.2 cm x 46.95 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 7 sec
- Fonts Included
- 93 x scalable , 1 , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB / 2 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS, IPPS
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 661 Watt
- Power Consumption Stand by
- 83 Watt
- Power Consumption Sleep
- 2.1 Watt
Environmental Standards
- ENERGY STAR
- 39 cm
- 53.2 cm
- 46.95 cm
- 30.5 kg
