A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.
Efficient printing technology
The Kyocera ECOSYS P4040dn leverages Kyocera ECOSYS Technology, ensuring efficiency and reliability for all your printing needs. This technology is designed to minimize environmental impact while providing a cost-effective solution to your office printing requirements. -
High-quality output
Achieve superior print quality with a maximum resolution of 1200 x 1200 DPI. Whether printing simple text documents or detailed graphics, the P4040dn delivers crisp, clear output every time, making it ideal for professional settings. -
Versatile media handling
With the ability to handle media sizes up to A3 (297 x 420 mm) and a variety of media types including plain paper, the P4040dn is exceptionally versatile. This flexibility allows for a wide range of printing tasks, from standard office documents to larger format prints. -
Robust monthly duty cycle
Designed for durability and longevity, the P4040dn boasts a monthly duty cycle of up to 150,000 pages. This robust performance capability makes it suitable for environments with high-volume printing needs. -
Eco-friendly and energy-efficient
ENERGY STAR certification ensures that the P4040dn is energy efficient, helping to reduce your office's carbon footprint and operating costs. Its low power consumption in sleep mode further enhances its eco-friendly attributes.
- Kyocera ECOSYS P4040dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 20 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 297 mm x 450 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 22 ppm - B/W - A3 (297 x 420 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- PowerPC 465 750 MHz
- RAM Installed (Max)
- 256 MB (1.25 GB)
- Language Simulation
- PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, XPS, EPSON LQ 850, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 20000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
- 1-year warranty
- 46.9 cm x 41 cm x 32 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 7.5 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 256 MB / 1.25 GB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- 70 mm x 148 mm
- 297 mm x 450 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 150000 pages
- 20000 pages
- Networking
- Print server
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 7500 pages ISO/IEC 19752
- TUV, ISO 9001, GS, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 586 Watt
- Power Consumption Sleep
- 1.5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 50.4 dBA
- Sound Emission (Quiet Mode)
- 49.6 dBA
- 46.9 cm
- 41 cm
- 32 cm
- 20 kg
