Kyocera ECOSYS P3155dn Mono Laser Printer
Quicklinx: F9SRWS00 Mfr#: 1102TR3NL0
When the going gets tough, you need a printer that exceeds all expectations to help you meet your deadline. The ECOSYS P3055dn does exactly that. With a print speed of up to 55 pages per minute, a fast time to first print and a superior 1,200 dpi resolution, it satisfies even the most demanding of workgroups. The device has enhanced security features and flexible paper handling options with a maximum paper capacity of 2,600 sheets. And its long life components mean incredibly low running costs and impact on the environment.
  • Efficient productivity
    With a first print out time of just 4.5 seconds and a high-speed processor clocked at 1.2 GHz, the Kyocera ECOSYS P3155dn ensures your work flows smoothly and efficiently, minimizing wait times and boosting productivity.
  • High-quality printing
    Achieve crisp, clear, and detailed monochrome prints with a maximum resolution of 1200 x 1200 DPI. Whether it's reports, documents, or banners, the quality of output is consistently impressive.
  • Versatile media handling
    From A6 to Legal sizes, and from plain to banner paper, the Kyocera ECOSYS P3155dn handles a wide range of media types and sizes through its 600-sheet total media capacity, including a 100-sheet multipurpose tray and a 500-sheet input tray, accommodating various printing needs.
  • Eco-friendly design
    ENERGY STAR certified and compliant with multiple environmental standards including ISO 14001 and RoHS, this printer not only meets your printing needs but also ensures environmental sustainability.
  • Advanced connectivity
    Featuring Gigabit Ethernet, USB 2.0, and USB host interfaces along with support for Apple AirPrint, Google Cloud Print, and Mopria Print Service, the Kyocera ECOSYS P3155dn offers flexible connectivity options for seamless integration into any modern workspace.
Kyocera ECOSYS P3155dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
16 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 140 mm
Max Media Size (Custom)
216 mm x 915 mm
Print Speed
Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 39 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 82 ppm - B/W - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
ARM Cortex-A9 1.2 GHz
RAM Installed (Max)
512 MB (2560 MB)
Language Simulation
PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, XPS, EPSON LQ 850, TIFF, JPEG, PDF Direct
Media Type
Plain paper, banner paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Print server
Printer Features
Kyocera ECOSYS Technology, Mopria certified
38 cm x 41 cm x 32 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
5-line backlit LCD display
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
4.5 sec
Language Simulation
Fonts Included
93 x outline , 1 x bitmapped , 45 x barcode
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB / 2560 MB (max)
Card Reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
70 mm x 140 mm
216 mm x 915 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Print server
Remote Management Protocol
SNMP 3, IPP
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752
TUV GS, ISO 9001, ISO 14001, RoHS, ISO 7779
Power supply - internal
Frequency Required
50/60 Hz
675 watt
Power Consumption Stand by
11 watt
Power Consumption Sleep
0.5 watt
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
55.8 dBA
Sound Emission (Quiet Mode)
51.1 dBA
38 cm
41 cm
32 cm
16 kg
