Kyocera ECOSYS P3150dn Mono Laser Printer
Quicklinx: F9SQWS00 Mfr#: 1102TS3NL0
With up to 50 pages per minute print speed, fast first print times, a powerful controller, mobile print support and low running costs, the ECOSYS P3050dn will be a welcome addition to any team. It also boasts enhanced security features with card authentication, private print and hard disk protection. And as you would expect of a KYOCERA printer, the long-life components and lower energy consumption ensure this device leaves a small environmental footprint.
  • Efficient printing technology
    The Kyocera ECOSYS P3150dn leverages Kyocera ECOSYS Technology, ensuring high efficiency and reliability. This technology minimizes waste and reduces maintenance costs, making it an eco-friendly choice for any office.
  • High-speed performance
    With a robust printing speed of up to 50 ppm for black and white documents and a first print out time of just 5.4 seconds, the P3150dn meets the demands of fast-paced work environments. Its powerful ARM Cortex-A9 processor clocked at 1.2 GHz ensures smooth operation and quick processing of complex print jobs.
  • Advanced connectivity options
    This printer supports a wide range of mobile printing capabilities, including Apple AirPrint, Google Cloud Print, and Mopria Print Service. Combined with Gigabit Ethernet and USB interfaces, it offers versatile connectivity options for any modern office setup.
  • Superior media handling
    The P3150dn excels in media flexibility, supporting a variety of media sizes from A6 to Legal and weights from 60 to 220 g/m2. With a total media capacity of 600 sheets, including a 100-sheet multipurpose tray, it can handle large print jobs with ease.
  • Eco-conscious and energy-efficient
    ENERGY STAR certification and a low power consumption mode highlight the P3150dn's commitment to energy efficiency. Its sound emission of 54.5 dBA during operation ensures a quieter work environment.
Kyocera ECOSYS P3150dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
15.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 140 mm
Max Media Size (Custom)
216 mm x 915 mm
Print Speed
Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 35.5 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 74 ppm - B/W - A5 (148 x 210 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
ARM Cortex-A9 1.2 GHz
RAM Installed (Max)
512 MB (2560 MB)
Language Simulation
PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, XPS, EPSON LQ 850, TIFF, JPEG, PDF Direct
Media Type
Plain paper, banner paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Print server
Printer Features
Kyocera ECOSYS Technology, Mopria certified
Environmental Standards
EPEAT Gold
38 cm x 41 cm x 32 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
5-line backlit LCD display
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5.4 sec
Language Simulation
Fonts Included
93 x outline , 1 x bitmapped , 45 x barcode
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB / 2560 MB (max)
Card Reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
70 mm x 140 mm
216 mm x 915 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Print server
Remote Management Protocol
SNMP 3, IPP
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 8000 pages ISO/IEC 19752
TUV GS, ISO 9001, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
636 watt
Power Consumption Stand by
11 watt
Power Consumption Sleep
0.5 watt
EPEAT Compliant
EPEAT Gold
ENERGY STAR
Sound Emission (Operating)
54.5 dBA
38 cm
41 cm
32 cm
15.5 kg
F9SQ Kyocera TK 3170 Black Toner Kit for ECOSYS P3050dn In Stock £83.10
