The P31xx ´series are very compact making then easy to accommodate on the desktop and with Gigabit networking as standard they are perfect for large and busy workgroups. Kyocera's long life image drum technology combined with large starter toners and high capacity replacement toners mean the P31xx series leads the way with very low running costs.
Efficient productivity
With a robust monthly duty cycle of up to 150,000 pages, the Kyocera ECOSYS P3145dn is engineered for reliability and efficiency, suitable for high-demand environments. -
Eco-friendly design
Leveraging Kyocera ECOSYS Technology, this printer offers long-life components that reduce waste and provide an eco-friendly printing solution, aligning with your green initiatives. -
Advanced connectivity
Supporting AirPrint, Google Cloud Print, and Mopria Print Service, the Kyocera ECOSYS P3145dn offers seamless integration into your existing mobile and cloud workflows, ensuring flexibility in how and where you print. -
High-quality printing
Achieve sharp, clear prints with a maximum resolution of 1200 x 1200 DPI, ensuring your documents look professional with exceptional detail and clarity. -
Secure and manageable
Featuring advanced security protocols including IPsec and SSL, along with SNMP 3 for efficient remote management, the Kyocera ECOSYS P3145dn safeguards your data and simplifies printer administration.
- Kyocera ECOSYS P3145dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 15.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 915 mm
- Print Speed
- Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 22.5 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 62 ppm - B/W - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM Cortex-A9 1.2 GHz
- RAM Installed (Max)
- 512 MB (2560 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, IBM ProPrinter XL24e, EPSON LQ 850, TIFF, JPEG, PDF Direct
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 20000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.9 or later
- 38.8 cm x 41 cm x 30.8 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5.3 sec
- Fonts Included
- 93 x outline , 1 x bitmapped , 45 x barcode
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB / 2560 MB (max)
Card Reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 915 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- 20000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, IPP
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
- TUV GS, ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 594 Watt
- Power Consumption Stand by
- 10 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 53.7 dBA
- 38.8 cm
- 41 cm
- 30.8 cm
- 15.5 kg
Kyocera TK 3160 Black Toner Kit for ECOSYS P3045dn | In Stock | £76.70 |
