Where performance meets affordability, the ECOSYS P3045dn is a very capable yet compact printer designed for smaller teams and workgroups. With a print speed of up to 45ppm, only 5.9 seconds to print the first page and comprehensive mobile print support, this printer will make printing easy and flexible for the whole team. In addition, the running costs and environmental impact of the device are kept exceptionally low thanks to its long-life components.
Finding the Serial Number:
Toner Change:
Unboxing:
Efficient printing speed
With a first print out time of just 5.9 seconds, the Kyocera ECOSYS P3045dn ensures your documents are ready when you need them, boosting productivity and efficiency in any work environment. -
High monthly duty cycle
Designed to handle the demands of high-volume printing, this printer boasts a monthly duty cycle range exceeding 100,000 pages, making it an ideal choice for businesses with heavy printing needs. -
Advanced connectivity options
Equipped with Gigabit Ethernet, USB 2.0, and USB host interfaces, along with Mopria Print Service for mobile printing capabilities, the Kyocera ECOSYS P3045dn offers versatile connectivity solutions for any office setup. -
Robust media handling
Supporting a wide range of media sizes and types, including A4, Legal, and plain paper, and with a maximum media capacity of 2600 sheets, this printer is well-suited for diverse printing tasks. -
Eco-friendly design
Featuring Kyocera ECOSYS Technology and ENERGY STAR certification, the P3045dn is designed for sustainability, reducing waste and energy consumption without compromising on performance.
- Kyocera ECOSYS P3045dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 14.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 45 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (2.5 GB)
- Language Simulation
- PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
- 1-year warranty
- 39.6 cm x 42.1 cm x 30.7 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5.9 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 2.5 GB (max)
Card Reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS, IPPS
- Secure Print, SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752
- TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 594 Watt
- Power Consumption Stand by
- 10 Watt
- Power Consumption Sleep
- 0.9 Watt
- Software Included
- Google Cloud Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year , Limited warranty - drum - 3 years or 300,000 pages
- Sound Emission (Idle)
- 27.1 dBA
- Sound Emission (Operating)
- 52.8 dBA
- Sound Emission (Quiet Mode)
- 51.5 dBA
- 39.6 cm
- 42.1 cm
- 30.7 cm
- 14.5 kg
