Kyocera ECOSYS P2040dw A4 Mono Laser Printer
Quicklinx: CKDYWS00 Mfr#: 1102RY3NL0
A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.
  • Efficient connectivity
    With interfaces for Gigabit Ethernet, USB 2.0, and USB host, alongside wireless readiness, the Kyocera ECOSYS P2040dw ensures seamless integration into any office environment, facilitating easy sharing among workgroups.
  • Eco-friendly operation
    Certified with ENERGY STAR for its energy efficiency, the Kyocera ECOSYS P2040dw also meets ISO 14001 and ISO 9001 standards, making it a smart choice for environmentally conscious businesses looking to reduce their carbon footprint while maintaining high productivity.
  • High-quality printing
    The Kyocera ECOSYS P2040dw boasts a maximum resolution of 1200 DPI for monochrome printing, ensuring sharp, clear documents. With support for various language simulations including PCL 5E, PCL 6, PostScript 3, and more, it accommodates a wide range of printing needs.
  • Robust media handling
    Capable of handling media sizes up to Legal (216 x 356 mm) and weights ranging from 60 to 220 g/m2, the printer is equipped with a 100-sheet multipurpose tray and a 250-sheet input tray, supporting a total media capacity of 350 sheets for efficient, uninterrupted printing operations.
  • Fast first print out
    The Kyocera ECOSYS P2040dw delivers the first print out in just 6.4 seconds, thanks to its powerful 800 MHz processor. This feature, combined with automatic duplexing, makes it an ideal solution for fast-paced work environments that demand efficiency and speed.
Kyocera ECOSYS P2040dw - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
14 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host, Wi-Fi
800 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Print server
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
37.5 cm x 39.3 cm x 27.2 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.4 sec
Language Simulation
Fonts Included
80 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Card Reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
350 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
Max Media Capacity
850 sheets
Output Trays Capacity
250 sheets
Print server
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
Frequency Required
50/60 Hz
620 watt
Power Consumption Stand by
8 watt
Power Consumption Sleep
0.8 watt
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
48.8 dBA
37.5 cm
39.3 cm
27.2 cm
14 kg
