Kyocera ECOSYS MA2100cwfx Colour Laser Multifunction Printer
Quicklinx: H6JDWS00 Mfr#: 110C0A3NL0
This entry-professional all-rounder meets any business requirements. The scan, copy, fax and mobile scan functions ensure an optimized workflow.
  • Efficient connectivity
    With a wide array of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi, alongside mobile printing capabilities through Apple AirPrint, Kyocera Mobile Print, and Mopria Print Service, this device ensures seamless integration into any work environment.
  • Advanced copying features
    Boasts automatic duplexing and a variety of copying features such as 2 on 1, 4 on 1, Auto Color Mode, and ID Card Copy, complemented by adjustable copy density and electronic sorting for enhanced document management.
  • High-quality printing and scanning
    Delivers exceptional color and B/W printing speeds up to 21 ppm with a maximum resolution of 9600 x 600 DPI, coupled with a scanning optical resolution of 600 x 600 DPI for capturing detailed images and documents.
  • Robust media handling
    Supports a broad range of media sizes and types, with a maximum media capacity of 550 sheets, ensuring flexibility in handling various document sizes and weights for all your office needs.
  • Eco-friendly design
    Designed with energy efficiency in mind, featuring a low power consumption in sleep mode of just 1 W, contributing to a greener office environment.
Kyocera ECOSYS MA2100cwfx - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
65000 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
JBIG, MH, MMR, MR
Fax Resolutions
200 x 100 dpi, 200 x 200 dpi, 200 x 400 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
A6 (105 x 148 mm) (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB host, USB 2.0, Gigabit LAN, Wi-Fi
AirPrint Enabled
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to FTP, scan to network, scan to SMB, scan to USB host
AC 230 V (50/60Hz)
41.7 cm x 42.9 cm x 49.5 cm
26 kg
1-year warranty
Printer Fonts
Scalable x 93 , Bitmapped x 1 , Barcode x 45
Fax Type
Plain paper
Printing Technology
Laser - colour
65000 pages
Display
5 lines
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Manual
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
Scan-once-copy-many, Auto Color Mode, electronic sorting, 2 on 1, 4 on 1, ID Card Copy, programme mode, adjustable copy density
Printing
Max Printing Speed
Printer Drivers / Emulations
PRESCRIBE IIc, PCL 6, PCL 5c, PCL 6 (XL), PostScript 3, KPDL3, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
12.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
JBIG, MH, MMR, MR
Fax Resolutions
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm)
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 70 x 148 mm
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
Multi-purpose tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 21 ppm (A4) - B/W , Printing: up to 21 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
MS Windows, Apple Mac OS X 10.8 or later, UNIX, Linux
AC 230 V (50/60Hz)
345 Watt
Power Consumption Standby
41 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
32 sec
First Copy Out Time B/W
10 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (yellow) , 1 x toner cartridge (magenta) , 1 x toner cartridge (cyan)
ISO 7779, ISO 9296, GS, TUV, ISO 9001, ISO 14001
Limited warranty - 1 year , Limited warranty - drum - 3 years or 100,000 pages , Limited warranty - developer - 3 years or 100,000 pages
41.7 cm
42.9 cm
49.5 cm
26 kg
Sound Emission
30 dBA (idle) / 48 dBA (operating)
