These A4 color devices are designed specifically for small and medium-sized work groups, offering both reliability and fast output speeds in both color and b/w. The convenient touch panels provide simple, direct access to the multifunctionals' numerous functions.
Efficient connectivity
With interfaces like Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for seamless mobile printing, this device ensures you stay connected in the most efficient way. -
Rapid performance
Experience swift printing and copying with speeds up to 35 ppm for both black and white and color, complemented by automatic duplexing to save time and resources. -
High-quality output
Achieve superior image clarity with a maximum resolution of 9600 x 600 DPI for both black and white and color printing, ensuring your documents look professional every time. -
Versatile media handling
From A6 to Legal sizes, and weights up to 220 g/m2, this printer accommodates a wide range of media types and sizes, making it ideal for various printing needs. -
Advanced scanning capabilities
With an optical resolution of 600 x 600 DPI and fast scanning speeds up to 60 ipm in black and white, this device simplifies document digitization and management.
- Kyocera ECOSYS M6035cidn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 100000 pages
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 1850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 47.5 cm x 55.8 cm x 61.6 cm
- 35.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Laser - colour
- 100000 pages
- Display Diagonal Size
- 7"
- Display Features
- Touch screen, tilt
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 2 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Control
- Automatic, manual
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 70 x 148 mm
- 350 sheets
- 1850 sheets
- 100 sheets
- 250 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour , Scanning: up to 60 ipm (A4) - B/W , Scanning: up to 40 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec, 802.1x
- Operating System Support
- UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
- Voltage Required
- 551 Watt
- Power Consumption Sleep
- 2.1 Watt
- Warm-Up Time
- 25 sec
- First Copy Out Time B/W
- 9 sec
- First Copy Out Time Colour
- 11 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages , 1 x toner cartridge (cyan) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (yellow) - up to 5000 pages
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- ENERGY STAR Certified
- Limited warranty - 1 year
- 47.5 cm
- 55.8 cm
- 61.6 cm
- 35.4 kg
- Sound Emission
- 49.9 dBA (operating)
