The ECOSYS M5526cdn combines the best color quality with the lowest of costs - and it will ease your workflow significantly, too. Its dual-scan document processor, the 4.3 inch touch screen for intuitive use, and program keys to simplify complex workflows improve productivity and quality this device as an absolute all-rounder. Furthermore, this device contains a long-yield toner with a capacity of up to 3,000 pages in color - offering unrivaled low costs per page. Rest assured, it is the perfect multifunctional partner for your business and will offer you a future of brilliant colors.
- Up to 26 pages per minute in A4 in colour and black and white
- 1,200 dpi printing quality
- 4,3 inch touch screen for easy operation
- Dual scan document processor
- Direct printing from and scanning to USB flash memory
- High security through SSL, IPsec and Private Print functionality
- Double-sided print, copy, scan and fax functionality as standard
- Compact design with low-noise printing
- Exceptionally low printing costs in its class
Why choose KYOCERA?
Efficient connectivity
With interfaces like Gigabit LAN, USB 2.0, and USB host, the Kyocera ECOSYS M5526cdn ensures seamless connectivity and integration into any work environment, bolstering productivity and ease of use. -
Advanced copying features
The device offers automatic duplexing, multiple copying features such as 2 on 1, 4 on 1, Auto Color Mode, and ID Card Copy, alongside electronic sorting, making it a versatile tool for all copying needs. -
High-quality printing
Achieve high-quality print results with resolutions up to 9600 x 600 DPI for both black and white and color documents, ensuring your prints are professional and crisp every time. -
Robust security
Equipped with robust security protocols including IPsec and SSL, the Kyocera ECOSYS M5526cdn protects sensitive information, making it a reliable choice for businesses concerned with data security. -
Eco-friendly design
ENERGY STAR certified, this model promotes energy efficiency with a low power consumption operational mode, contributing to a greener office environment.
- Kyocera ECOSYS M5526cdn - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 26 ppm (mono) / up to 26 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Scanning
- 600 x 600 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 550 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
- 41.7 cm x 42.9 cm x 49.5 cm
- 26 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Reception Memory Capacity
- Up to 256 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Remote Fax Retrieval (Polling)
- Fax polling, Duplex Fax
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
- 300 sheets
- 550 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - colour , Printing: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour , Scanning: up to 24 ipm (A4) - B/W duplex , Scanning: up to 16 ipm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Operating System Support
- UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
- 375 Watt
- Power Consumption Standby
- 41 Watt
- Power Consumption Sleep
- 1 Watt
- Warm-Up Time
- 29 sec
- First Copy Out Time B/W
- 8 sec
- First Copy Out Time Colour
- 10 sec
- Consumables Included
- 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages , 1 x toner cartridge (black) - up to 1200 pages
- ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 41.7 cm
- 42.9 cm
- 49.5 cm
- 26 kg
- Sound Emission
- 30 dBA (idle) / 49 dBA (operating)
Kyocera TK 5240K - black - original - toner cartridge | In Stock | £49.02 |
Kyocera TK 5240C - cyan - original - toner cartridge | In Stock | £72.89 |
Kyocera Black Toner Cassette 4K | In Stock | £49.02 |
Kyocera Cyan Toner Cassette 3K | In Stock | £72.89 |
Kyocera KYO Magenta Toner Cassette 3K | In Stock | £72.89 |
