The ECOSYS M5521cdw A4 professional all-rounder meets any business requirements. The scan, copy, fax and mobile scan functions ensure an optimized and flexible workflow. Mobile printing support takes this to the next level and offers every office the most modern standards in technology. The direct printing functions (via Wi-Fi and USB host) keep your work running seamlessly.
- Up to 21 pages per minute in A4 in colour and black and white
- 1,200 dpi printing quality
- WiFi and WiFi direct as standard
- Mobile printing support including AirPrint, Mopria, KYOCERA Mobile Print
- Double-sided print, copy, scan and fax functionality as standard
- Direct printing from and scanning to USB flash memory
- Compact design with low-noise printing
- Exceptionally low printing costs in its class
Regardless of your business workflow requirements, this professional all-rounder will meet or exceed them. With all of the functionality you would expect, including scan, mobile scan, copy and fax, your workflow will be as optimised and as flexible as you require. Mobile print support takes this to the next level with support for both Apple and Android de-vices. In addition, the KYOCERA MyPanel app opens up the functionality of this device and enables you to operate the device via your smartphone. All in all, this powerful device fits seamlessly into any business.
Finding the Serial Number:
Toner Change:
Unboxing:
WiFi Set Up:
Efficient connectivity
With options like Gigabit Ethernet, USB 2.0, and USB host, alongside wireless capabilities including AirPrint and mobile printing, this device ensures seamless integration into any work environment. -
Advanced copying features
Boasts a range of copying functionalities such as 2 on 1, 4 on 1, Auto Color Mode, ID Card Copy, Scan-once-copy-many, and electronic sorting, making it a versatile tool for any copying need. -
High-quality printing
Achieves up to 9600 x 600 DPI resolution for both black and white and color printing, ensuring sharp, vivid outputs with automatic duplexing for efficient paper usage. -
Robust scanning and faxing
Offers a solid optical resolution of 600 x 600 DPI for scanning and Super G3 compatibility for fast fax transmissions, enhancing office productivity. -
Eco-friendly design
ENERGY STAR certified, this model promotes energy efficiency with a low power consumption during sleep mode, aligning with environmental standards and reducing operational costs.
- Kyocera ECOSYS M5521cdw - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 65000 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 550 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
- Power
- AC 230 V (50Hz)
- 41.7 cm x 42.9 cm x 49.5 cm
- 26 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Laser - colour
- 65000 pages
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 1.5 GB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, PRESCRIBE IIc
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 12.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
- 300 sheets
- 550 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 21 ppm (A4) - colour , Printing: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - colour , Scanning: up to 30 ppm - B/W , Scanning: up to 23 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Operating System Support
- UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
- Voltage Required
- AC 230 V (50Hz)
- 345 watt
- Power Consumption Standby
- 41 watt
- Power Consumption Sleep
- 1 watt
- Warm-Up Time
- 32 sec
- First Copy Out Time B/W
- 10 sec
- First Copy Out Time Colour
- 12 sec
- ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 41.7 cm
- 42.9 cm
- 49.5 cm
- 26 kg
- Sound Emission
- 30 dBA (idle) / 48 dBA (operating)
Kyocera TK-5230C Cyan Toner Cassette | In Stock | £75.70 |
Kyocera TK-5230Y Yellow Toner | In Stock | £75.70 |
Kyocera Black Toner Cassette 2.6K | In Stock | £51.44 |
Kyocera Cyan Toner Cassette 2.2K | In Stock | £75.70 |
Kyocera Magenta Toner Cassette 2.2K | In Stock | £75.70 |
Kyocera Yellow Toner Cassette 2.2K | In Stock | £75.70 |
Kyocera TK 5220K Black Original Toner Cartridge | In Stock | £40.39 |
Kyocera TK 5220M Magenta Original Toner Cartridge | In Stock | £54.52 |
Kyocera TK 5220Y Yellow Original Toner Cartridge | In Stock | £51.92 |
