Kyocera ECOSYS M3645dn Mono Laser Multifunction Printer
Quicklinx: FM53WS00 Mfr#: 1102TG3NL0
These MFPs are made for any team that needs high levels of versatility and productivity. Featuring fast print speeds, the additional features of double-sided scanning and copying as well as the integrated file compression function mean that these devices are ready to adapt to your changing needs. Thanks to their long-life components, these MFPs can achieve exceptionally low running costs as well as the low environmental impact you have come to expect from a genuine Kyocera.
  • Efficient connectivity
    With a suite of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Google Cloud Print, Kyocera Mobile Print, and Mopria Print Service, this device ensures seamless integration into any workflow.
  • Advanced security
    Equipped with AES, IPsec, and SSL, the Kyocera ECOSYS M3645dn offers robust security protocols to protect sensitive information, making it a suitable choice for environments where data security is important.
  • High-speed performance
    Achieve efficiency with a first copy out time of just 7 seconds, and a maximum copying speed of 45 ppm. Automatic duplexing and a first print out time of 5.9 seconds further enhance productivity.
  • Versatile media handling
    This model boasts comprehensive media handling capability, supporting sizes from 70 x 148 mm to Legal (216 x 356 mm) and weights up to 220 g/m2, making it suitable for a wide range of document types.
  • Eco-friendly operation
    ENERGY STAR certification ensures that the Kyocera ECOSYS M3645dn operates efficiently, reducing environmental impact while also lowering operating costs.
Kyocera ECOSYS M3645dn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 45 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 45 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, print from e-mail, IPP printing, scan to USB host
AC 230 V (50Hz)
47.5 cm x 47.6 cm x 57.5 cm
22.3 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
5 lines x 21 characters
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
3 GB
Hard Disk Drive
128 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Up to 45 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, blank page skipping, electronic sorting
Printing
Max Printing Speed
Up to 45 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, TIFF, XPS, EPSON LQ-850, IBM Proprinter X24E, PRESCRIBE IIc, JPEG
Automatic Duplexing
First Print Out Time B/W
5.9 sec
Colour Management Features
Mopria
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
Fax polling, Duplex Fax
Document & Media Handling
Max Original Size
Original Type
Sheets
75 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
50 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), 70 x 148 mm, 148 x 140 mm
600 sheets
Max Media Capacity
2600 sheets
100 sheets
250 sheets
Input tray - 500 sheets size: 140 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , RADF - 75 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 45 ppm (A4) - B/W , Printing: up to 22.5 ppm (A4) - B/W duplex , Copying: up to 22.5 ppm (A4) - B/W duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, AES
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
AC 230 V (50Hz)
652 Watt
Power Consumption Standby
50 Watt
Power Consumption Sleep
0.5 Watt
Warm-Up Time
16 sec
First Copy Out Time B/W
7 sec
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
ENERGY STAR Certified
47.5 cm
47.6 cm
57.5 cm
22.3 kg
Sound Emission
30 dBA (idle) / 54 dBA (operating)
FM53 Kyocera TK 3160 Black Toner Kit for ECOSYS P3045dn In Stock £76.58
