Kyocera ECOSYS M3540idn A4 Mono Laser Multifunction Printer
Quicklinx: C5Y9WS00 Mfr#: 1102NX3NL0
For workgroups who demand a compact, flexible and easy to use multifunctional device, the ECOSYS 3540idn offers the ideal solution. It has been designed to maximize efficiency of document throughput whilst minimizing user time. Thanks to its full color touch screen operation panel and integrated HyPAS platform, users can customize this device to suit its specific needs. With output speeds of 40 pages per minute users need also not compromise on workflow efficiency. Add to this, long-life components that provide exceptional reliability and low running costs which minimize the impact on the environment, this device really does offer an unbeatable package.
  • Efficient connectivity
    With features like Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint capability, this device ensures seamless integration into any work environment, enabling easy connection and print jobs from various devices.
  • Advanced security
    Equipped with IPsec and SSL, the Kyocera ECOSYS M3540idn offers robust security protocols to protect sensitive information, ensuring peace of mind for users.
  • High-quality copying
    Automatic duplexing, a range of exposure modes, and a maximum copying resolution of 600 x 600 DPI combine to deliver high-quality copies quickly and efficiently, with the first copy out in just 9 seconds.
  • Versatile media handling
    This model boasts a maximum media capacity of 2600 sheets, supports a wide range of media sizes and types, and includes a bypass feeder for special print jobs, making it ideal for businesses with diverse printing needs.
  • Eco-friendly operation
    ENERGY STAR certification signifies that the Kyocera ECOSYS M3540idn not only meets high standards of efficiency but also operates with a reduced environmental impact, aligning with sustainability goals.
Kyocera ECOSYS M3540idn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
7"
Original Size
105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology
AC 230 V (50/60Hz)
47.5 cm x 45.5 cm x 57.5 cm
22 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
150000 pages
Display Diagonal Size
7"
Display Features
Touch screen, tilt
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
2 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
Automatic Duplexing
First Print Out Time B/W
9 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
One-Touch Dialing
22 station(s)
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
Original Type
Sheets
75 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
600 sheets
Max Media Capacity
2600 sheets
100 sheets
250 sheets
Input tray - 500 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Copying: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 30 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
685 Watt
Power Consumption Standby
61.6 Watt
Power Consumption Sleep
2.4 Watt
Warm-Up Time
21 sec
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 6000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
47.5 cm
45.5 cm
57.5 cm
22 kg
Sound Emission
27.3 dBA (idle) / 51.5 dBA (operating)
