These MFPs are a great choice for demanding work groups (small to large) looking for a compact, flexible and easy-to-use device combined with outstanding low running costs. Simplified login possibilities eliminate access bottlenecks while keeping the security of your documents high.
Efficient connectivity
With options like AirPrint, Google Cloud Print, Kyocera Mobile Print, and Mopria Print Service, this device ensures seamless integration into any workflow, enabling easy mobile printing. -
Advanced security
Equipped with AES, IPsec, SNMP 3, and SSL, the Kyocera ECOSYS M3145IDN offers robust security protocols to protect sensitive information, ensuring peace of mind for users. -
High-speed performance
Boasting a first copy out time of just 7 seconds and a maximum copying speed of 45 ppm, this model is designed for efficiency, reducing wait times and increasing productivity. -
Versatile media handling
From A6 to Legal sizes, and weights from 50 g/m2 to 220 g/m2, this device handles a wide range of media, making it suitable for various document types and sizes. -
Eco-friendly design
ENERGY STAR certified, the Kyocera ECOSYS M3145IDN is designed with eco-friendly considerations, featuring a low power consumption in sleep mode of just 0.5 watts, aligning with sustainability goals.
- Kyocera ECOSYS M3145IDN - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 45 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 45 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 2600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB, print from e-mail, IPP printing, scan to USB host
- Power
- AC 230 V (50Hz)
- 47.5 cm x 47.6 cm x 57.5 cm
- 22.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- Display Diagonal Size
- 7"
- Display Colour Support
- Display Features
- Touch screen, tilt, speaker
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 3 GB
- Hard Disk Drive
- 128 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Up to 45 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, blank page skipping, electronic sorting
Printing
- Up to 45 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, TIFF, XPS, EPSON LQ-850, IBM Proprinter X24E, PRESCRIBE IIc, JPEG
- First Print Out Time B/W
- 5.9 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 50 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), 70 x 148 mm, 148 x 140 mm
- 600 sheets
- 2600 sheets
- 100 sheets
- 250 sheets
- Input tray - 500 sheets size: 140 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , RADF size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 45 ppm (A4) - B/W , Printing: up to 22.5 ppm (A4) - B/W duplex , Copying: up to 22.5 ppm (A4) - B/W duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
- 1 x USB 2.0 , 2 x USB 2.0 host , 1 x Gigabit LAN - RJ-45
- SSL, IPsec, AES, SNMP 3
- Operating System Support
- UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
- Voltage Required
- AC 230 V (50Hz)
- 652 watt
- Power Consumption Standby
- 50 watt
- Power Consumption Sleep
- 0.5 watt
- Warm-Up Time
- 21 sec
- First Copy Out Time B/W
- 7 sec
- TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 47.5 cm
- 47.6 cm
- 57.5 cm
- 22.5 kg
- Sound Emission
- 30 dBA (idle) / 54 dBA (operating)
