These MFPs are made for any team that needs high levels of versatility and productivity. Featuring fast print speeds, the additional features of double-sided scanning and copying as well as the integrated file compression function mean that these devices are ready to adapt to your changing needs. Thanks to their long-life components, these MFPs can achieve exceptionally low running costs as well as the low environmental impact you have come to expect from a genuine Kyocera.
Efficient connectivity
With a range of connectivity options including AirPrint, Google Cloud Print, and Kyocera Mobile Print, this device ensures seamless integration into any workflow. Gigabit Ethernet and USB 2.0 ports offer high-speed connections to multiple devices. -
Advanced security
Equipped with AES, IPsec, SNMP 3, and SSL protocols, the Kyocera ECOSYS M3145DN provides robust security features to protect sensitive information, ensuring peace of mind for users. -
High-speed copying and printing
Achieve maximum productivity with fast copying and printing speeds up to 45 ppm and a first copy out time of just 7 seconds. Automatic duplexing enhances efficiency by facilitating double-sided printing and copying without manual intervention. -
Versatile media handling
This model boasts a flexible media handling capability, supporting sizes from A6 to Legal and weights from 50 to 220 g/m2. With a maximum media capacity of 2600 sheets, it meets the demands of high-volume tasks. -
Eco-friendly design
ENERGY STAR certification signifies this printer's commitment to energy efficiency. Kyocera's ECOSYS technology further enhances its environmental sustainability by reducing waste, making it an ideal choice for eco-conscious businesses.
- Kyocera ECOSYS M3145DN - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 45 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 45 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 2600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, print from e-mail, IPP printing, scan to USB host
- Power
- AC 230 V (50Hz)
- 47.5 cm x 47.6 cm x 57.5 cm
- 22.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Laser - monochrome
- Display
- 5 lines x 21 characters
- Display Features
- Speaker, backlight
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
- Max Supported Memory
- 3 GB
- Hard Disk Drive
- 128 GB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Up to 45 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo, map
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, blank page skipping, electronic sorting
Printing
- Up to 45 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, TIFF, XPS, EPSON LQ-850, IBM Proprinter X24E, PRESCRIBE IIc, JPEG
- First Print Out Time B/W
- 5.9 sec
- Colour Management Features
- Mopria
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 50 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), 70 x 148 mm, 148 x 140 mm
- 600 sheets
- 2600 sheets
- 100 sheets
- 250 sheets
- Input tray - 500 sheets size: 140 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , RADF size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
- Speed Details
- Printing: up to 45 ppm (A4) - B/W , Printing: up to 22.5 ppm (A4) - B/W duplex , Copying: up to 22.5 ppm (A4) - B/W duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
- 1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN - RJ-45
- SSL, IPsec, AES, SNMP 3
- Operating System Support
- UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
- Voltage Required
- AC 230 V (50Hz)
- 652 watt
- Power Consumption Standby
- 50 watt
- Power Consumption Sleep
- 0.5 watt
- Warm-Up Time
- 16 sec
- First Copy Out Time B/W
- 7 sec
- TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
- ENERGY STAR Certified
- 47.5 cm
- 47.6 cm
- 57.5 cm
- 22.3 kg
- Sound Emission
- 30 dBA (idle) / 54 dBA (operating)
Kyocera TK 3160 Black Toner Kit for ECOSYS P3045dn | In Stock | £80.21 |
