Kyocera ECOSYS M3040idn A4 Mono Multifunction Laser Printer
Quicklinx: BP14WS00 Mfr#: 1102NY3NL0
This MFP is the best choice for demanding work groups looking for a compact, flexible and easy-to-use device. Simplified login possibilities eliminate access bottlenecks while keeping the security of your documents high. The document workflow can easily be optimized thanks to the individually customizable color touch panel and the integrated open solution platform HyPAS. The long-life components provide exceptional reliability and low running costs and help keeping the environmental impact to an absolute minimum.
  • Efficient connectivity
    With a range of connectivity options including Gigabit Ethernet, USB 2.0, and USB host, alongside mobile printing capabilities through Apple AirPrint, this device ensures seamless integration into any work environment.
  • Advanced security
    Equipped with robust security protocols such as IPsec and SSL, the Kyocera ECOSYS M3040idn safeguards sensitive information, providing peace of mind with every print, copy, and scan.
  • High productivity
    Automatic duplexing, a 7" touchscreen display, and a maximum monthly duty cycle of 150,000 pages are designed to boost productivity and efficiency in busy office settings.
  • Superior media handling
    Accommodates a wide range of media sizes and weights, with a maximum media capacity of 2600 sheets, ensuring versatile document handling capabilities for all business needs.
  • Eco-friendly performance
    ENERGY STAR certified, the Kyocera ECOSYS M3040idn incorporates ECOSYS technology, promoting environmental sustainability while delivering cost-effective operation.
Kyocera ECOSYS M3040idn - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Scanning
600 x 600 dpi
Display
7"
Original Size
105 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
75 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology
AC 230 V (50/60Hz)
47.5 cm x 45.5 cm x 57.5 cm
22 kg
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Printing Technology
Laser - monochrome
150000 pages
Display Diagonal Size
7"
Display Features
Touch screen, tilt
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
2 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 40 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort
Printing
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, EPSON LQ-850, IBM Proprinter X24E, Lineprinter
Automatic Duplexing
First Print Out Time B/W
9 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Min Original Size
105 x 148 mm
Max Original Size
Original Type
Sheets
75 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
600 sheets
Max Media Capacity
2600 sheets
100 sheets
250 sheets
Input tray - 500 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 75 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Copying: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 30 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
684 Watt
Power Consumption Standby
60.6 Watt
Power Consumption Sleep
2.4 Watt
Warm-Up Time
21 sec
First Copy Out Time B/W
9 sec
Consumables Included
1 x toner cartridge (black) - up to 6000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
47.5 cm
45.5 cm
57.5 cm
22 kg
Sound Emission
27.8 dBA (idle) / 51.5 dBA (operating)
