The Kyocera FS-C8600 A4 Colour Laser Printer is ideal for workgroups with high volume needs who demand a specific, professional quality, secure print solution. The FS C8600 delivers A3 print speeds of 22 ppm in colour and mono, with automatic duplex for double sided documents and 1024Mb of RAM to aid larger document processing with support for local storage of commonly used graphics and forms to reduce network loads. The FSC 8600 boasts flexibile media handling options, including stapling, hole punching, folding and document sorting. Integrated security features like departmental codes and command center enable access and user function restrictions, thus increasing document security and allowing status monitoring locally or via a web browser.
Efficient productivity
With a robust monthly duty cycle of up to 225,000 pages, the Kyocera FS C8600DN is engineered for reliability and high-volume printing, making it an ideal choice for busy office environments. -
Exceptional print quality
Achieve outstanding print clarity with a maximum resolution of 9600 x 600 DPI for both black and white and color documents, ensuring your reports, presentations, and graphics stand out. -
Versatile media handling
This printer accommodates a wide range of media sizes from A6 to A3 and weights from 60 g/m2 to 300 g/m2, including banners and plain paper, providing flexibility for all your printing needs. -
Advanced connectivity
Equipped with Gigabit Ethernet and USB host interfaces, the Kyocera FS C8600DN offers seamless integration into your existing network, ensuring efficient workflow and productivity. -
Eco-friendly operation
Featuring Kyocera ECOSYS Technology and ENERGY STAR certification, this printer not only delivers high-quality prints but also operates with environmental efficiency, reducing waste and energy consumption.
- Kyocera FS-C8600DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 111 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Max Media Size (Custom)
- 304.8 mm x 1219 mm
- Print Speed
- Up to 22 ppm - B/W - A3 (297 x 420 mm) , Up to 22 ppm - colour - A3 (297 x 420 mm) , Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 45 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- Processor
- PowerPC 750GL 750 MHz
- RAM Installed (Max)
- 1 GB (2 GB)
- Card Reader
- Hard Drive
- 160 GB
- Language Simulation
- PostScript 3, PCL 6, PRESCRIBE IIe, XPS, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper, banners
- Total Media Capacity
- 1150 sheets
- Media Handling
- 2x 500-sheet input trays, 150-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 225000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
- Microsoft Certification
- Compatible with Windows 7
- 67.2 cm x 78.7 cm x 74.4 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5.4 sec
- First Print Out Time Colour
- 6.6 sec
- Fonts Included
- 93 x scalable PCL , 136 x scalable PostScript , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 1 GB / 2 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Storage
- Hard Drive
- 160 GB
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 1150 sheets
- Media Feeders
- 2 x automatic - 500 sheets - ARCH B (304.8 x 457.2 mm) weight: 60 g/m² - 256 g/m² , 1 x automatic - 150 sheets - 304.8 x 1219.2 mm weight: 60 g/m² - 300 g/m²
- Max Media Capacity
- 7650 sheets
- Output Trays Capacity
- 750 sheets
Duty Cycle
- 225000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP
- Expansion Slots
- 1 x expansion slot , Memory
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 15000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 10000 pages ISO/IEC 19798
- TUV, ISO 9001, GS, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1140 Watt
- Power Consumption Stand by / Sleep
- 170 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 33.9 dBA
- Sound Emission (Operating)
- 52.6 dBA
- 67.2 cm
- 78.7 cm
- 74.4 cm
- 111 kg
