Say goodbye to the days of slow flatbed scanning! Scanning pictures and other memorabilia is now fast and easy - with great profit potential - thanks to the Kodak Picture Saver Scanning Systems PS50. Just think - while it used to take one to two minutes to scan a single photo on a flatbed, you can now scan up to 85 photos in just one minute! And the image quality and automatic enhancements are simply dazzling, thanks to easy-to-use, intuitive Kodak picture saver scanning software.
Gentle photo handling
With the Kodak gentle photo separation module, the specially designed transport treats every photo with extra-gentle care. -
Kodak Perfect Touch technology built in
For bright, vibrant colors and rich detail in addition to the ability to improve contrast and color balance and correct red eye. -
Flexible workflow
Start, stop, or reopen an existing scanning job at any point in the capture-edit-output cycle; this gives you the flexibility. -
Automatic image straightening
It delivers auto deskew for proper image alignment. -
Software-based image cleaning
Reduce artifacts from environmental factors, such as dust.
- Kodak Picture Saver Scanning System PS50 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 215 x 863 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 50 ppm (colour)
- Max Document Size
- 302 mm x 461 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows XP SP3, Microsoft Windows XP 64-bit Edition SP2, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- 33 cm x 16.2 cm x 24.6 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 215 x 863 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 50 ppm
- Scanner Speed Details
- 50 ppm - landscape - 10x15cm - 300 dpi
- Scanner Features
- Color Dropout, Automatic Image Orientation, automatic colour detection, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, Deskew
- TWAIN
Media Handling
- Max Document Size
- 302 mm x 461 mm
- Plain paper
- Automatic
- 50 sheets
- USB 2.0
- Included Accessories
- Dust cover
- GOST, CISPR 22 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC CFR47 Part 15 B, S Mark, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, ICES-003 issue 4 Class B, UL 60950-1-07
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 32 Watt (0.35 Watt)
- Software Included
- Drivers & Utilities, KODAK Smart Touch
- OS Required
- 33 cm
- 16.2 cm
- 24.6 cm
- 5.5 kg
- 10 °C
- 35 °C
- 15 - 76%
