Kodak ALARIS S2070 Scanner
Quicklinx: DKCQWS00 Mfr#: 1015049
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 3000 mm
Interface: USB 3.1
Compatibility: PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£602.58 ex VAT
£723.09 inc VAT
Built to simplify and speed up your day-to-day business processes, the Kodak ALARIS S2070 A4 Sheetfed Scanner allows users to scan documents with ease so that you can maximise productivity in the office. With this machine, you don't have to compromise quality for efficiency either, as its data accuracy and impressive image resolution will keep your documents looking sharp.
Efficient scanning
This sheetfed scanner by Kodak has the ability to scan up to 70 pages per minute at a speed of 140ipm, so you can keep your productivity at a maximum while the office runs smoothly. With Embedded Image Processing, the scanner delivers high-quality, sharp images without you having to rely on a computer. Active Feed technology also prevents multifeeds and misfeeds while the Controlled Output Stacking feature stacks documents in a neat pile in the output tray so that you don't have to waste time tidying up.
Protect important documents
This scanner is perfect for an office that handles sensitive documents as its Intelligent Exception Processing feature identifies any missing information so that it can be dealt with straight away. You can also rest assured that any important documents will remain in good condition as the scanner's multifeed sensor technology and Intelligent Document Protection software prevent pages from jamming and becoming damaged. For documents containing sensitive data, this scanner contains industry-standard security protocols to prevent data and images from being compromised in transit.
Streamlined functionality
With predefined job setups, this scanner allows users to alter its configuration with a single click or by quickly scanning a QR code generated automatically. It's also possible to connect to applications including Salesforce, SharePoint, Dropbox, OneDrive and more so that your scanned documents can be uploaded with ease.
  • Embedded image processing
    Save money at all steps in the scanning process, with innovation that takes out overhead costs. Embedded image processing delivers crisp, high-quality images at full speed without depending on a super-powered PC. Intelligent features help reduce manual pre- and post-scan tasks.
  • Intuitive user display
    Start up faster and stay productive with ease-of-use features. The intuitive color displays make scanning quick and easy.
  • Active Feed technology
    Keep working without worrying about jams, thanks to a paper path built for exceptional reliability. Active Feed automatically jogs pages to avoid misfeeds. Maintain maximum uptime with SurePath paper handling.
  • Optical character recognition
    Get the right information the first time, with OCR read rates that are more accurate. Perfect Page technology delivers superior image quality with 30+ enhancements automatically for more accurate image extraction.
Kodak S2070 - document scanner - desktop - USB 3.1
Document scanner - desktop
Interface Type
USB 3.1
Light Source
RGB LED array
Max Supported Document Size
216 x 3000 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
70 ppm (mono) / 70 ppm (colour)
Max Document Size
216 mm x 3000 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
7000 scans per day
Microsoft Windows Server 2008 x64 Edition, Ubuntu, Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
31.2 cm x 20.4 cm x 18.25 cm
7.2 kg
5-year warranty
Interface Type
USB 3.1
216 x 3000 mm
Scanner
Input Type
Grayscale Depth
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
70 ppm
Max Document Scan Speed Colour
70 ppm
Duty Cycle
7000 scans per day
Scanner Features
Automatic colour detection, auto white balance, dual-stream scanning, image merge
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 3000 mm
Automatic
80 sheets
Interfaces Details
USB 3.1
TUV GS, BSMI, EN 60950, CCC, UL 60950-1, FCC CFR47 Part 15 B, EN 55024:2010, EN 55022:2010, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B, GB 4943.1-2011, CNS 14336-1, CAN/CSA-C22.2 No. 60950-1-07+A1:2011
Environmental Standards
EPEAT Compliant
EPEAT Gold
Internal power supply
Power Consumption Operational (Standby)
36 watt
Power Consumption Stand by
0.5 watt
System Requirements Details
Core i3 - 3.5 GHz - RAM 3.43 GB
31.2 cm
20.4 cm
18.25 cm
7.2 kg
Advanced Exchange Service - Next Business Day Onsite Support - 5 years
10 °C
35 °C
15 - 80%
Interface: USB 3.1
Compatibility: PC
Brand: Kodak
Price Range Ex VAT: £500 - £750
