The Kodak ALARIS S2050 A4 Sheetfed Scanner is ideal for businesses and organisations with mid-level volumes of daily scanning. Accurate, clear and easy to use, it fits nicely into any office environment.
Fast, reliable scanning
This scanner captures a healthy 50 pages per minute, enabling you to quickly record and file the information that your business needs. Incorporating an 80 sheet automatic document feeder (ADF), it can handle a recommended 5,000 pages per day.
Active Feed technology helps prevents paper misfeeds so that you don’t have to worry about having to clear jams. In fact, Sure Path Paper Handling technology helps maintain maximum uptime, enabling you to continue working without interruptions. And when you come back to the device, the Controlled Output integration ensures your pages are neatly stacked up and ready in the output tray.
High-quality images and text
Embedded Image Processing ensures speedily delivered crisp and vivid images. Superior image quality is also enhanced by Perfect Page technology. When it comes to text documents, Optical Character Recognition (OCR) delivers read rates that have up to 10% more accuracy than similar models.
Intuitive and easy to use
The intuitive user display with Easy Setup feature allows you to quickly install preconfigured settings. This helps you get started quickly without having to wait around fiddling with the options. In fact, you can save up to 20 job setups and destinations, so once you’ve configured it, you can scan using previously used setups. Unlike other scanners, you don’t need to rely on a PC to help deliver your images.
Superb information delivery
Advanced Capture software helps you send the scanned information to specific destinations, in the right format. Choose which ECM systems you want the documents to go to, whether that be Cloud destinations, FTP, local or network folders. Even better, you can extract specific data from the scanned documents for use in specific business systems and processes.
Embedded image processing
Save money at all steps in the scanning process, with innovation that takes out overhead costs. Embedded image processing delivers crisp, high-quality images at full speed without depending on a super-powered PC. Intelligent features help reduce manual pre- and post-scan tasks. -
Intuitive user display
Start up faster and stay productive with ease-of-use features. The intuitive color displays make scanning quick and easy. -
Keep working without worrying about jams, thanks to a paper path built for exceptional reliability. Active Feed automatically jogs pages to avoid misfeeds. Maintain maximum uptime with SurePath paper handling. -
Optical character recognition
Get the right information the first time, with OCR read rates that are more accurate. Perfect Page technology delivers superior image quality with 30+ enhancements automatically for more accurate image extraction.
- Kodak S2050 - document scanner - desktop - USB 3.1
- Document scanner - desktop
- Interface Type
- USB 3.1
- Light Source
- RGB LED array
- Max Supported Document Size
- 216 x 3000 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels)
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 50 ppm (colour)
- Max Document Size
- 216 mm x 3000 mm
- Supported Document Type
- Plain paper, business card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 80 sheets
- Duty Cycle
- 5000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Server 2008 x64 Edition, Ubuntu, Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
- 31.2 cm x 20.4 cm x 18.25 cm
- 7.2 kg
- 5-year warranty
- Interface Type
- USB 3.1
- 216 x 3000 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth (External)
- 600 dpi x 600 dpi
- Bulb / Light Source Type
- RGB LED array
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 50 ppm
- Duty Cycle
- Scanner Features
- Automatic colour detection, auto white balance, dual-stream scanning, image merge
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 3000 mm
- Automatic
- 80 sheets
- Interfaces Details
- USB 3.1
- TUV GS, BSMI, EN 60950, CCC, UL 60950-1, FCC CFR47 Part 15 B, EN 55024:2010, EN 55022:2010, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B, GB 4943.1-2011, CNS 14336-1, CAN/CSA-C22.2 No. 60950-1-07+A1:2011
Environmental Standards
- EPEAT Compliant
- EPEAT Gold
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 36 watt
- Power Consumption Stand by
- 0.5 watt
- OS Required
- System Requirements Details
- Core i3 - 3.5 GHz - RAM 3.43 GB
- 31.2 cm
- 20.4 cm
- 18.25 cm
- 7.2 kg
- Advanced Exchange Service - Next Business Day Replacement Support - 5 years
- 10 °C
- 35 °C
- 15 - 80%
