Busy mailrooms, production departments and service bureaus have relied on KODAK i4000 Series Scanners for years to deliver a valuable combination of quality, productivity, and affordability. They're a great choice for plowing through hours of uninterrupted scanning.
Speed through huge jobs with time-saving features and the muscle to handle up to 125,000 scans a day. Larger interactive control panel lets operators do more without leaving the scanner for the host PC. Manage multi-feeds, avoid document damage and reduce the need for rescans with Intelligent Document Protection and auto image rotation. Control the most complicated workflows on the fly with advanced barcode reading.
A fresh take on great performance
Busy mailrooms, production departments and service bureaus have relied on KODAK i4000 Series Scanners for years to deliver a valuable combination of quality, productivity, and affordability. They're a great choice for plowing through hours of uninterrupted scanning. -
Minimize interruptions, maximize productivity
Speed through huge jobs with time-saving features and the muscle to handle up to 125,000 scans a day. Larger interactive control panel lets operators do more without leaving the scanner for the host PC. Manage multi-feeds, avoid document damage and reduce the need for rescans with Intelligent Document Protection and auto image rotation. Control the most complicated workflows on the fly with advanced barcode reading. -
Image quality that's close to perfect
Get crisp, clear images even with challenging originals, thanks to the latest Perfect Page image processing technology. Stay productive with improved document feeding Spend less time loading documents and more time getting your work done thanks to a 500-sheet input tray and controlled stacking technology. Easily scan a mixture of documents of different sizes and thicknesses - from business cards to file folders. -
It's easier than ever to take control
Easily eliminate interruptions in big multi-batch jobs with simple patch counting and front-side imprinting technology.
- Kodak i4850 - document scanner - desktop - USB 3.0
- Document scanner - desktop
- Interface Type
- USB 3.0
- Scanning Sensor Type
- CCD
- Light Source
- White LED array
- Max Supported Document Size
- 304.8 x 5300 mm
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 160 ppm (mono) / 160 ppm (colour)
- Max Document Size
- 304.8 mm x 5300 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 500 sheets
- Duty Cycle
- 150000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Ubuntu 14.04 LTS (64-bit)
- 48.9 cm x 46.73 cm x 34.79 cm
- 30.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- 90 days warranty
- Interface Type
- USB 3.0
- 304.8 x 5300 mm
Scanner
- Input Type
- 600 dpi x 600 dpi
- CCD
- Bulb / Light Source Type
- White LED array
- Max Document Scan Speed B/W
- 160 ppm
- Max Document Scan Speed Colour
- 160 ppm
- Duty Cycle
- Scanner Speed Details
- 160 ppm - landscape B&W - 200 dpi , 160 ppm - landscape colour - 300 dpi
- Scanner Features
- Multi Color Dropout, Automatic Image Orientation, iThresholding, Perfect Page, dual-stream scanning, Punch Hole Removal, Intelligent Document Protection, Intelligent Imprinting
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- Plain paper
- Automatic
- 500 sheets
- Interfaces Details
- USB 3.0 - Type B
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 130 Watt
- Power Consumption Stand by
- 1.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Software Included
- KODAK Capture Pro Software Limited Edition
- OS Required
- 48.9 cm
- 46.73 cm
- 34.79 cm
- 30.4 kg
- Limited warranty - 90 days - on-site
- Sound Emission
- 63 dBA
