Kodak i3500 Scanner
Kodak i3500 Scanner
Quicklinx: DKCVWS00 Mfr#: 1065036
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Kodak scanners are purpose-built to deliver consistent throughput and minimize downtime for your office. They're loaded with impressive imaging functionality for onboarding batches of information, and intelligent document protection to defend against damaged documents and lost data. These rotary scanners can take on virtually any challenge, while taking up less space on your desk - making them the perfect fit for any business, that doesn't have a second to waste.
  • Dependable performance
    Get reliable throughput in color, black and white, at 200 or 300 dpi, on images, text, and mixed-size documents.
  • Intelligent, integrated and ready, when you are
    Save time and get exceptional value with scanners, that think and work like you do. Features like Smart Touch technology let you perform multi-step scanning processes with the press of a button. Perfect Page technology optimizes images, enabling functions like optical character recognition (OCR) be more accurate, while built-in barcode reading delivers data to applications.
  • Built for ease, productivity, and longevity
    Shorten the learning curve with devices, designed to impress experienced employees and make life easier. Space-saving engineering delivers robust paper transport and heavy-duty features in a compact, desktop-friendly design.
Kodak I3500 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
305 x 4100 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
110 ppm (mono) / 110 ppm (colour)
Max Document Size
305 mm x 4100 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
Duty Cycle
25000 scans per day
Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.8 - 10.10, Ubuntu 14.04 LTS, Windows 10 (32/64 bits)
43.18 cm x 37.1 cm x 23.8 cm
15.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
305 x 4100 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
110 ppm
Max Document Scan Speed Colour
110 ppm
Duty Cycle
25000 scans per day
Scanner Speed Details
110 ppm - A4 / Letter - 300 dpi
Scanner Features
Color Dropout, Automatic Image Orientation, automatic colour detection, built-in LCD screen, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, image merge, Ultrasonic Multi Feed Detection, auto brightness, Deskew, Blank Page Detection, Continuous Scanning
TWAIN, ISIS, WIA
Media Handling
Max Document Size
305 mm x 4100 mm
Plain paper
Automatic
300 sheets
Interfaces Details
USB 2.0
1 x USB cable
FCC Class B certified, TUV GS, C-Tick, CISPR 22 Class B, cUL, EN 61000-3-3, CCC, IEC 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 9254 Class B, CAN/CSA C22.2 No. 60950-1-07, GB 9254-2008, UL 60950-1-07, ICES-003 issue 5 Class B, CNS13438:2006, VCCI V-3/2012.04 Class B, EN 60950-1:2006+ A11, GB 17625.1-2003, EN 55024:2010, AS/NZS CISPR22:2009+A1:2010, GB 4943.1-2011, EN 55022:2010 Class B
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
49 Watt
Power Consumption Stand by
2.8 Watt
Power Consumption Sleep
0.5 Watt
Software Included
Drivers & Utilities, KODAK Smart Touch, NewSoft Presto! PageManager, KODAK Capture Pro Software Limited Edition
43.18 cm
37.1 cm
23.8 cm
15.8 kg
15 °C
35 °C
15 - 80%
Sound Emission
60 dBA
