The Kodak i3000 series scanner is purpose-built to deliver consistent throughput and minimize downtime for your office. It is loaded with impressive imaging functionality for on boarding of information, and intelligent document protection to defend against damaged documents and lost data. The A3 rotary scanner can take on virtually any challenge while taking up less space on your desk - making it the perfect fit for any business that doesn't have a second to waste.
Missions accomplished
The Kodak i3000 series delivers consistently high throughput. Whether you're scanning in color or black and white, at 300 dpi, images, text or mixed-size documents - it doesn't matter, it just gets done. -
Give productivity a major lift
Stack up the work. With a 250-sheet feeder/elevator you can neatly and efficiently scan document batches with ease. The design ensures continuous throughput with rapid-fire scanning and less risk of jamming. -
It's even smart enough to know when something's not right
Intelligent document protection provides an added level of document and data safeguarding. "Intelligent" because it listens for the very first indication of potential document damage from staples, paper clips or other obstructions. At the initial sound of any issue, sensors stop the scanning process to allow you to take appropriate action and correct the irregularity. -
Better than ever
Kodak Alaris' Perfect Page technology optimizes image quality and intelligently manages a host of image processing tasks. It all happens automatically, with every scan. -
Intelligent by design
Scanning is really only half the story. Configuring image profiles, defining job names and file destinations, and distributing information is truly crucial. That's where Kodak Alaris' Smart Touch functionality takes over. It streamlines repetitive tasks like filing to your server, simplifies distribution of content, and makes access to your data easy, whether you're in the office or out on the road. -
Works incredibly well with others
Easily integrates with all TWAIN, ISIS, and Linux-based scanning applications so managing your data is just as easy as scanning your documents. -
Built to meet the demands of today and the rigors of tomorrow
Make no mistake, these scanners are made to last. Designed to impress your most experienced employees and make life easier for workers who are just getting started. When it comes to getting work done day after day, depend on scanners that truly deliver. -
Flexible input for inflexible documents
Some contracts are not just unbreakable, they're unbendable, too. For those instances, simply choose the straight-through paper path option. This bypasses rotary scanning, enabling you to feed thick or exceptionally long documents right through. -
Impact made compact
Proof that a smaller design doesn't have to compromise features, it has managed to engineer heavy-duty features into a device that takes up less space on your desk and less time in your day. -
The smart touch graphical user display
Pre-configured scanning setups make common, yet complicated scanning tasks easy.
- Kodak i3250 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 304.8 x 4064 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 50 ppm (colour)
- Max Document Size
- 304.8 mm x 4064 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 250 sheets
- Duty Cycle
- 20000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits) SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
- 43.18 cm x 37.1 cm x 25.7 cm
- 17.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3 months warranty
- Interface Type
- USB 2.0
- 304.8 x 4064 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 50 ppm
- Duty Cycle
- Scanner Speed Details
- 50 ppm - landscape B&W - Letter - 300 dpi , 100 ipm - duplex - landscape B&W - Letter - 300 dpi , 50 ppm - landscape greyscale - Letter - 300 dpi , 100 ipm - duplex - landscape greyscale - Letter - 300 dpi , 50 ppm - landscape colour - Letter - 300 dpi , 100 ipm - duplex - landscape colour - Letter - 300 dpi
- Scanner Features
- Color Dropout, Ultrasonic Double Feed Detection, Automatic Image Orientation, automatic colour detection, built-in LCD screen, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, image merge, auto brightness, Deskew, Blank Page Detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- Plain paper
- Automatic
- 250 sheets
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x SuperSpeed USB cable
- UL, TUV GS, C-Tick, cUL, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, VCCI Class B
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 75 Watt (0.5 Watt)
- Software Included
- Drivers & Utilities, KODAK Capture Desktop Software, KODAK Smart Touch
- OS Required
- 43.18 cm
- 37.1 cm
- 25.7 cm
- 17.7 kg
- Limited warranty - 3 months - on-site - response time: next business day
- 15 °C
- 35 °C
- 15 - 80%
- Sound Emission
- 60 dBA
