The Kodak i3000 series scanner is purpose-built to deliver consistent throughput and minimize downtime for your office. It is loaded with impressive imaging functionality for on boarding of information, and intelligent document protection to defend against damaged documents and lost data. The A3 rotary scanner can take on virtually any challenge while taking up less space on your desk - making it the perfect fit for any business that doesn't have a second to waste.
- Kodak i3200 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scan Element Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 304.8 x 4064 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 50 ppm (colour)
- Max Document Size
- 304.8 mm x 4064 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 250 sheets
- Duty Cycle
- 15000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits) SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
- 43.18 cm x 37.1 cm x 23.75 cm
- 15.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 304.8 x 4064 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Element Type
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 50 ppm
- Duty Cycle
- Scanner Speed Details
- 50 ppm - landscape B&W - Letter - 300 dpi , 100 ipm - duplex - landscape B&W - Letter - 300 dpi , 50 ppm - landscape greyscale - Letter - 300 dpi , 100 ipm - duplex - landscape greyscale - Letter - 300 dpi , 50 ppm - landscape colour - Letter - 300 dpi , 100 ipm - duplex - landscape colour - Letter - 300 dpi
- Scanner Features
- Color Dropout, Ultrasonic Double Feed Detection, Automatic Image Orientation, automatic colour detection, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, touch screen LCD display, adaptive threshold processing, image merge, auto brightness, Deskew, Blank Page Detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- Plain paper
- Automatic
- 250 sheets
- USB 2.0
- Cables Included
- 1 x USB cable
- UL, TUV GS, C-Tick, cUL, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, VCCI Class B
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 75 Watt (0.5 Watt)
- Software Included
- Drivers & Utilities, KODAK Capture Desktop Software, KODAK Smart Touch
- OS Required
- System Requirements Details
- Core 2 Duo RAM 3 GB
- 43.18 cm
- 37.1 cm
- 23.75 cm
- 15.8 kg
- 15 °C
- 35 °C
- 15 - 76%
- Sound Emission
- 40 dBA
