Kodak i3200 A3 Document Scanner
Quicklinx: FSD8WS00 Mfr#: 1641745#S4691941/emgo
  • Windows 8 (32/64 bits)
The Kodak i3000 series scanner is purpose-built to deliver consistent throughput and minimize downtime for your office. It is loaded with impressive imaging functionality for on boarding of information, and intelligent document protection to defend against damaged documents and lost data. The A3 rotary scanner can take on virtually any challenge while taking up less space on your desk - making it the perfect fit for any business that doesn't have a second to waste.
  • Missions accomplished
    The Kodak i3000 series delivers consistently high throughput. Whether you're scanning in color or black and white, at 300 dpi, images, text or mixed-size documents - it doesn't matter, it just gets done.
  • Give productivity a major lift
    Stack up the work. With a 250-sheet feeder/elevator you can neatly and efficiently scan large or small batches with ease. The design ensures continuous throughput with rapid-fier scanning and less risk of jamming.
  • Tear through work, not paper
    Intelligent document protection is on duty for every document you scan. So scan fearlessly, with the assurance that your documents - and the information they contain - are protected.
  • Better than ever
    Kodak's Perfect Page technology optimizes image quality and intelligently manages a host of image processing tasks. It all happens automatically, with every scan.
  • Intelligent by design
    Scanning is really only half the story. Configuring image profiles, defining job names and file destinations, and distributing information is truly crucial. That's where Kodak's Smart Touch functionality takes over. It streamlines repetitive tasks like filing to your server, simplifies distribution of content, and makes access to your data easy, whether you're in the office or out on the road.
  • Built to meet the demands of today and the rigors of tomorrow
    Make no mistake, these scanners are made to last. Designed to impress your most experienced employees and make life easier for workers who are just getting started. When it comes to getting work done day after day, depend on scanners that truly deliver.
  • Flexible input for inflexible documents
    Some contracts are not just unbreakable, they're unbendable, too. This bypasses rotary scanning, enabling you to feed thick or exceptionally long documents right through.
Kodak i3200 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
304.8 x 4064 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
304.8 mm x 4064 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
250 sheets
Duty Cycle
15000 scans per day
Microsoft Windows Vista (32/64 bits) SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
43.18 cm x 37.1 cm x 23.75 cm
15.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
304.8 x 4064 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Duty Cycle
15000 scans per day
Scanner Speed Details
50 ppm - landscape B&W - Letter - 300 dpi , 100 ipm - duplex - landscape B&W - Letter - 300 dpi , 50 ppm - landscape greyscale - Letter - 300 dpi , 100 ipm - duplex - landscape greyscale - Letter - 300 dpi , 50 ppm - landscape colour - Letter - 300 dpi , 100 ipm - duplex - landscape colour - Letter - 300 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Automatic Image Orientation, automatic colour detection, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, touch screen LCD display, adaptive threshold processing, image merge, auto brightness, Deskew, Blank Page Detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
304.8 mm x 4064 mm
Plain paper
Automatic
250 sheets
Interfaces Details
USB 2.0
1 x USB cable
UL, TUV GS, C-Tick, cUL, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, VCCI Class B
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
75 Watt (0.5 Watt)
Software Included
Drivers & Utilities, KODAK Capture Desktop Software, KODAK Smart Touch
System Requirements Details
Core 2 Duo RAM 3 GB
43.18 cm
37.1 cm
23.75 cm
15.8 kg
15 °C
35 °C
15 - 76%
Sound Emission
40 dBA
