The Kodak i2900 scanner is a robust rotary A4 desktop scanner with an ingenious book-edge flatbed scanner built right in. It features a 250-sheet feeder/elevator and consistently high throughput speed, even when imaging double-sided and color documents at up to 300 dpi. Add in intelligent document protection, as well as Kodak's Perfect Page technology and Smart Touch functionality, and you've got a fiercely powerful scanner in a remarkably compact package.
Smaller footprint, bigger impact
A robust design takes up less space but can still take on heavy-duty scanning challenges. -
Give productivity a lift
With a 250-sheet feeder/elevator you can neatly and efficiently scan large or small batches of mixed-size documents with ease. -
Flatbed at your fingertips
The integrated book-edge A4 flatbed scanner is designed to handle all kinds of exception documents. So book pages, passports, folders, fragile documents and more are simply no match for the Kodak i2900. -
Upgrade your uptime
With intelligent document protection you can scan confidently, knowing that each document is safeguarded from the potential of damage during feeding. -
Total control with a touch
Kodak's Smart Touch functionality streamlines repetitive tasks, simplifies information sharing, and makes your scanning life easier. -
Better than ever
Kodak's Perfect Page technology optimizes image quality for data extraction and intelligently handles image-processing tasks - delivering extended functionality to many applications.
- Kodak i2900 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 216 x 4064 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 60 ppm (mono) / 60 ppm (colour)
- Max Document Size
- 216 mm x 4064 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 250 sheets
- Duty Cycle
- 10000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits) SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
- 43.18 cm x 37.1 cm x 23.75 cm
- 15.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 4064 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 60 ppm
- Max Document Scan Speed Colour
- 60 ppm
- Duty Cycle
- Scanner Speed Details
- 60 ppm - portrait B&W - Letter - 300 dpi , 120 ipm - duplex - portrait B&W - Letter - 300 dpi , 60 ppm - portrait greyscale - Letter - 300 dpi , 120 ipm - duplex - portrait greyscale - Letter - 300 dpi , 60 ppm - portrait colour - Letter - 300 dpi , 120 ipm - portrait colour - Letter - 300 dpi
- Scanner Features
- Color Dropout, Ultrasonic Double Feed Detection, Automatic Image Orientation, automatic colour detection, built-in LCD screen, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, image merge, auto brightness, Deskew, Blank Page Detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 4064 mm
- Plain paper
- Automatic
- 250 sheets
- USB 2.0
- Cables Included
- 1 x USB cable
- UL, TUV GS, C-Tick, cUL, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, VCCI Class B
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 75 Watt (0.5 Watt)
- Software Included
- Drivers & Utilities, Alaris Smart Touch, Alaris Capture Desktop Software
- OS Required
- System Requirements Details
- Core 2 Duo RAM 3 GB
- 43.18 cm
- 37.1 cm
- 23.75 cm
- 15.8 kg
- 15 °C
- 35 °C
- 15 - 76%
- Sound Emission
- 30 dBA
