Kodak I2420 A4 Colour Document Scanner
Quicklinx: CCMSWS00 Mfr#: 1120435
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
To keep your business process humming, you need a scanning solution that combines great image quality, simple operation and time-saving productivity. The Kodak i2000 Series Scanners offer all that in a very small yet powerful package.
  • Impressive productivity
    No need for warmup time, so you can start scanning instantly. Then keep moving through mountains of documents.
  • Superior image quality
    Capture images with greater clarity and more consistent color. Built-in Perfect Page technology automatically delivers clear, crisp images, which minimizes the need for rescanning or post-image processing.
  • No expertise required
    Smart Touch technology lets you perform up to nine different tasks with the push of a button.
  • Space-saving design
    The innovative stow-or-go design lets you store the scanner upright when not in use, taking up minimal desktop space.
  • Endless versatility
    Handle almost any kind of document: small or large, thick or thin - and expand your possibilities by scanning bound, oversize, and fragile documents.
Kodak i2420 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
216 x 4064 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 4064 mm
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Duty Cycle
5000 scans per day
Red Hat Fedora Core 10, Microsoft Windows Server 2008 x64 Edition, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Ubuntu 12.04, SuSE Linux 11.1, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Ubuntu 14.04 LTS, Windows 10 (32/64 bits), Ubuntu 16.04 LTS
33 cm x 16.2 cm x 24.6 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 4064 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
40 ppm - black & white - 200 dpi , 40 ppm - black & white - 300 dpi , 40 ppm - colour - 200 dpi , 80 ipm - black & white - 300 dpi , 80 ipm - black & white - 200 dpi , 80 ipm - colour - 200 dpi , 40 ppm - colour - 300 dpi , 80 ipm - colour - 300 dpi
Scanner Features
Automatic Image Orientation, Ultrasonic multifeed sensor, automatic colour detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 4064 mm
Automatic
75 sheets
USB 2.0 - Type A
TUV GS, C-Tick, VCCI Class B ITE, CISPR 22 Class B, BSMI CNS 13438 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, FCC CFR47 Part 15 B, S Mark, AS/NZS 3548 Class B, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
32 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
4 Watt
System Requirements Details
Core 2 Duo - 2.4 GHz - RAM 4 GB , MacOS - Core i7 - 2 GHz - RAM 4 GB
33 cm
16.2 cm
24.6 cm
5.5 kg
10 °C
35 °C
15 - 80%
