Take a moment to think about those multiple-step scanning operations that are done again and again, day after day. Scanning, editing, naming, choosing a file format - it's so repetitive. Now imagine the time and money you could save by doing all that at the press of a button. That's what Kodak's smart touch functionality is all about.
The Kodak i2400 scanner with built-in Smart Touch functionality lets you capture, manage, process, and deliver PDFs and other file formats - automating processes that previously were time-consuming.
More productivity, more imaging power
Dual LED illumination gets you started faster by eliminating lamp warmup time to provide immediate response, plus image clarity, consistency, and color stability. -
More versatility
The extendable, self-storing output tray and flexible paper handling will take care of just about anything you want to scan - small documents or large, thick or thin, ID cards, even embossed hard cards. -
More reliability
The highly reliable 50-sheet feeder and integrated paper tray make it easy to get scanning done.
- Kodak i2400 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 216 x 4064 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 30 ppm (mono) / 30 ppm (colour)
- Max Document Size
- 216 mm x 4064 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 2000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP SP2, Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows XP SP3, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows XP 64-bit Edition SP2, Microsoft Windows 7 (32/64 bits), Ubuntu 10.04.1
- Microsoft Certification
- Compatible with Windows 7
- 33 cm x 16.2 cm x 24.6 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 4064 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 30 ppm
- Max Document Scan Speed Colour
- 30 ppm
- Duty Cycle
- Scanner Speed Details
- 30 ppm - black & white - 200 dpi , 30 ppm - colour - 200 dpi , 30 ppm - black & white - 300 dpi , 30 ppm - colour - 300 dpi , 60 ipm - colour - 200 dpi , 60 ipm - black & white - 200 dpi , 60 ipm - colour - 300 dpi , 60 ipm - black & white - 300 dpi
- Scanner Features
- Automatic Image Orientation, Ultrasonic multifeed sensor, automatic colour detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 4064 mm
- Plain paper
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type A
- Cables Included
- 1 x USB cable
- TUV GS, C-Tick, VCCI Class B ITE, CISPR 22 Class B, BSMI CNS 13438 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, FCC CFR47 Part 15 B, S Mark, AS/NZS 3548 Class B, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 32 Watt (4 Watt)
- Software Included
- Drivers & Utilities, KODAK Capture Desktop Software, Nuance PaperPort, Nuance OmniPage, KODAK Smart Touch
- OS Required
- System Requirements Details
- Core 2 Duo - 2.1 GHz - RAM 2 GB
- 33 cm
- 16.2 cm
- 24.6 cm
- 5.5 kg
- 10 °C
- 35 °C
- 15 - 76%
- Sound Emission
- 53 dBA
