Kodak ESP 6150 Wireless Printer
Quicklinx: 6M4QWS00 Mfr#: 3950581
With the Kodak ESP Office 6150 All-in-One Printer you can easily print, copy, scan, and fax from your home office, delivering the quality your business deserves, without straining your bottom line.
This specially designed printer uses patented pigmented inks - instead of dyes - so you get richer, fuller, longer-lasting colors every time you hit print. And because the printer only uses fairly priced ink, it has the lowest total ink replacement cost in the industry. That means you can spend your time focusing on your business - and not worrying about overpaying for ink. If you're looking for a printer that multi tasks as much as you do without compromising budgets or quality, you'll love the Kodak ESP Office 6150 - the more affordable solution for your business.
Kodak ESP 6150 All-in-One - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
6-ink
Max Copying Speed
Up to 27 ppm (mono) / up to 26 ppm (colour)
Max Printing Speed
Up to 32 ppm (mono) / up to 30 ppm (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 dpi
Display
2.4"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper
Standard Media Capacity
200 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
44.5 cm x 42.7 cm x 23.6 cm
8.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour - photo
Display Diagonal Size
2.4"
Copying
Max Copying Speed
Max Document Enlargement
500%
Max Document Reduction
20%
Maximum Copies
99
Printing
Max Printing Speed
6-ink
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Interpolated Resolution
9600 dpi
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 100 pages
Document & Media Handling
Max Original Size
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), 100 x 150 mm
200 sheets
Input tray - 200 sheets , ADF - 30 sheets
Speed Details
Printing: up to 32 ppm - B/W , Printing: up to 30 ppm - colour , Printing: 29 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 27 ppm - B/W , Copying: up to 26 ppm - colour
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows 7, MS Windows XP Home Edition SP2 or later, MS Windows Vista, Apple MacOS X 10.4.8 or later
Software Included
Drivers & Utilities
Consumables Included
1 x ink cartridge (black) - Kodak 10XL , 1 x ink cartridge (colour)
ENERGY STAR Certified
Limited warranty - 1 year
44.5 cm
42.7 cm
23.6 cm
8.5 kg
