microSDHC card offers higher storage capacities for more music, more videos, more pictures, more games - more of everything you need in today's mobile world. The microSDHC card allows you to maximize today's revolutionary mobile devices. Kingston's microSDHC cards use the peed "class" rating that guarantee a minimum data transfer rate for optimum performance with devices that use microSDHC.
Identical in physical size to today's standard microSD card, the microSDHC cards are designed to comply with SD specification version 2.00 and are only recognized by microSDHC host devices. To ensure compatibility, look for the microSDHC or SDHC logo on host devices (e.g. phones, PDAs, and cameras).
Versatile
When combined with the adapter, it can be used as a full-size SDHC card. -
Compatible
With microSDHC host devices, it is not compatible with standard microSD-enabled device/readers.
- Kingston - flash memory card - 4 GB - microSDHC
- Product Type
- Flash memory card
- Form Factor
- microSDHC
- Storage Capacity
- 4 GB
- Speed Rating
- Class 4
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 4 GB
- Speed Class
- Class 4
- Read Rate
- Up to 4 MB/s
- Form Factor
- microSDHC
- Limited warranty - lifetime
