Kingston 256GB Canvas Select Plus microSD
Quicklinx: FN16WS00 Mfr#: SDCS2/256GB
26 In Stock
£12.92 ex VAT
£15.50 inc VAT
Kingston’s Canvas Select Plus microSD is compatible with Android devices and designed with A1 rated performance. It offers improved speed and capacity for loading apps faster and capturing images and videos. Powerful in performance, speed, and durability, the Canvas Select Plus microSD is designed for reliability when shooting and developing high-resolution photos or filming and editing Full HD videos. Kingston Canvas cards are durable in the harshest environments and conditions so you can take them anywhere with confidence that your photos, videos, and files will be protected.
  • Faster speeds
    Class 10 UHS-I speeds up to 100MB/s.
  • Optimized for use with Android devices
    Improved performance when used with an Android smartphone or tablet.
  • Great capacity
    Excellent capacity to store all your memorable photos and videos.
  • Durable
    For your peace of mind, the card is waterproof, temperature proof, shock and vibration proof and X-ray proof.
Kingston Canvas Select Plus - flash memory card - 256 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
256 GB
Speed Rating
A1 / Video Class V30 / UHS Class 3 / Class10
Included Memory Adapter
microSDXC to SD adapter
Flash memory card
Storage Capacity
256 GB
Speed Class
Read Rate
Up to 100 MB/s
Write Rate
Up to 85 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
11 mm
15 mm
Thickness
1 mm
-25 °C
85 °C
Type: microSDXC UHS-I Memory Card
Capacity: 256GB
SD Speed Class: A1 / Video Class V30 / UHS Class 3 / Class10
Brand: Kingston
