Kingston’s Canvas Select Plus SD card is designed with exceptional performance, speed, and durability for heavy workloads such as transferring and developing high-resolution photos or capturing and editing Full HD videos. It can reach Class 10 UHS-I speeds up to 100MB/s for easy storage and quick transfers along with an advanced UHS-I interface that can record cinematic Full HD and 4K Ultra HD videos. The Canvas Select Plus SD card is built to perform in the harshest environments and conditions so you can take it anywhere knowing your files, photos, and videos are protected.
Faster speeds
Class 10 UHS-I speeds up to 100MB/s. -
Capture in Full HD & 4K UHD video (1080p)
The advanced UHS-I interface makes the card ideal for cinema-quality Full HD (1080p). -
Excellent capacity
Great capacity to store all your memorable photos and videos. -
Durable
For your peace of mind, the card is waterproof, temperature proof, shock and vibration proof and X-ray proof.
- Kingston Canvas Select Plus - flash memory card - 64 GB - SDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDXC UHS-I Memory Card
- Storage Capacity
- 64 GB
- Speed Rating
- Video Class V10 / UHS-I U1 / Class10
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 64 GB
- Speed Class
- Read Rate
- Up to 100 MB/s
- Form Factor
- Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
- Limited warranty - lifetime
- 24 mm
- 32 mm
- 2.1 mm
- -25 °C
- 85 °C
