Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for Apple Mac Pro Workstation.
- Kingston - DDR2 - kit - 4 GB: 2 x 2 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
- Product Type
- Memory kit
- Capacity
- 4 GB: 2 x 2 GB
- Memory Type
- DDR2 SDRAM - FB-DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 667 MHz (PC2-5300)
- Latency Timings
- CL5
- Fully Buffered
- Voltage
- 1.8 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Apple MA987
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Capacity
- 4 GB: 2 x 2 GB
- Upgrade Type
- System specific
- Apple MA987
- DRAM memory kit
- Technology
- DDR2 SDRAM
- Form Factor
- FB-DIMM 240-pin
- Speed
- Latency Timings
- CL5
- ECC
- Fully Buffered
- Module Configuration
- 256 x 72
- Voltage
- 1.8 V
- Lead Plating
- Gold
- Compatible Slots
- 2 x memory - FB-DIMM 240-pin
