Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR3 - module - 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Unbuffered
- Limited lifetime warranty
- Designed For
- Dell PowerEdge C6100, C6105, M420, M610, M610x, M620, R210 II, R220, R320, R410, R510, R610, R620, R710, R720, R720xd, T20, T20 Mini Tower Server, T320, T410, T610, T620; Precision T1650, T3600, T5600
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Dell PowerEdge C6100, C6105, M420, M610, M610x, M620, R210 II, R220, R320, R410, R510, R610, R620, R710, R720, R720xd, T20, T20 Mini Tower Server, T320, T410, T610, T620 , Dell Precision T1650, T3600, T5600
