Kingston 64GB Canvas Select Class 10 UHS-I SD Card
Quicklinx: DD9RWS00 Mfr#: SDS/64GB
Kingston’s Canvas Select™ SD card is designed to be reliable, making it ideal for filming in HD and shooting hi-resolution photos on your point-and-shoot camera. This card is tested to be durable1, so you can take it anywhere with confidence that your photos, videos and other data will be protected.
  • Full HD
    The advanced UHS-I interface makes the card ideal for cinema-quality full HD (1080p) and 3D video.
  • Made for video
    Capture your holiday, football game or night on the town using this Class 10 card.
  • Get your memories faster
    Transfer and edit your memories quicker thanks to the incredible 8x read speeds over traditional Class 10 SD cards.
Kingston Canvas Select - flash memory card - 64 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
64 GB
Speed Rating
UHS-I U1 / Class10
Flash memory card
Storage Capacity
64 GB
Speed Class
UHS-I U1 / Class10
Read Rate
Up to 80 MB/s
Write Rate
Up to 10 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
