Kingston's Canvas Go! microSD card is designed to be on-the-go, making it ideal for filming life's adventures in 1080p or even 4K. You can be confident that your memories will be safe when documenting the next journey on your GoPro, drone, or dash cam.
Made for movement
Capture your latest hike, underwater adventure, or that sweeping landscape using this UHS-I U3 card. -
4K video
The advanced UHS-I U3 interface makes the card ideal for cinema-quality 4K video. -
Get your memories faster
Transfer and edit your memories quicker thanks to the incredible 9x read speeds over traditional Class 10 SD cards.
- Kingston Canvas Go! - flash memory card - 64 GB - SDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDXC UHS-I Memory Card
- Storage Capacity
- 64 GB
- Speed Rating
- Video Class V30 / UHS-I U3 / Class10
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 64 GB
- Speed Class
- Read Rate
- Up to 90 MB/s
- Write Rate
- Up to 45 MB/s
- Form Factor
- Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
- Limited warranty - lifetime
- 24 mm
- 32 mm
- 2.1 mm
- -25 °C
- 85 °C
