Kingston 512GB Canvas Go SDXC Card
Quicklinx: DS80WS00 Mfr#: SDG/512GB
Kingston's Canvas Go! microSD card is designed to be on-the-go, making it ideal for filming life's adventures in 1080p or even 4K. You can be confident that your memories will be safe when documenting the next journey on your GoPro, drone, or dash cam.
  • Made for movement
    Capture your latest hike, underwater adventure, or that sweeping landscape using this UHS-I U3 card.
  • 4K video
    The advanced UHS-I U3 interface makes the card ideal for cinema-quality 4K video.
  • Get your memories faster
    Transfer and edit your memories quicker thanks to the incredible 9x read speeds over traditional Class 10 SD cards.
Kingston Canvas Go! - flash memory card - 512 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
512 GB
Speed Rating
Video Class V30 / UHS-I U3 / Class10
Flash memory card
Storage Capacity
512 GB
Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 45 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
