Easily move photos, music and data between digital devices. This all-in-one media kit gives mobile users the compatible storage they need for all SD and USB-compatible devices, including mobile phones, digital cameras, notebooks, media players and more. Store your entire mobile life - photos, songs, text messages, video clips and personal information on your card, then work with it across device platforms seamlessly with the versatile Kingston Multi-Kit/Mobility Kit at your fingertips.
Versatile compatibility
Designed to seamlessly integrate with both Mac and PC systems, the Kingston Multi-Kit / Mobility Kit ensures a smooth user experience across different platforms. This adaptability makes it an ideal solution for users who operate in diverse computing environments. -
Comprehensive kit
The kit includes a microSD card, a microSD to SD adapter, and a USB reader, providing users with a complete solution for their data storage and transfer needs. Whether it's expanding storage or transferring files, this kit covers all bases. -
Optimal temperature range
With an operating temperature range from 0°C to 60°C, the flash memory card is built to perform reliably under various environmental conditions. This durability ensures that your data remains safe and accessible, regardless of the climate.
- Kingston Multi-Kit / Mobility Kit - flash memory card - 4 GB - microSDHC
- Product Type
- Flash memory card
- Bundled with
- USB Reader
- Form Factor
- microSDHC
- Storage Capacity
- 4 GB
- Speed Rating
- Class 4
- Included Memory Adapter
- microSDHC to SD adapter
- OS Required
- Microsoft Windows 7, Linux 2.6.x or later, Microsoft Windows Vista SP2, Apple MacOS X 10.5.x or later, Microsoft Windows Vista SP1, Microsoft Windows XP SP3
- Limited lifetime warranty
- Product Type
- Flash memory card
- Bundled with
- USB Reader
- Storage Capacity
- 4 GB
- Speed Class
- Class 4
- Form Factor
- microSDHC
- OS Required
- Limited warranty - flash memory card - lifetime , Limited warranty - card reader - 2 years
- 11 mm
- 15 mm
- Thickness
- 1 mm
- 0 °C
- 60 °C
