Kingston 1GB DDR3-1066 Module
Quicklinx: 6DLNWS00 Mfr#: KTT1066D3/1G
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR3 - module - 1 GB - SO-DIMM 204-pin - 1066 MHz / PC3-8500 - unbuffered
Memory module
1 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1066 MHz (PC3-8500)
Unbuffered
Limited lifetime warranty (Germany, Austria and France - 10 years)
Toshiba Satellite A500, A500/02, A665, A665D, C655, C655D, L450, L500, L505, L550, L555, L645, L655, L655D, L675, L675D, P500, P505, T110, T130, U500, U500/00
1 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
1066 MHz (PC3-8500)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 204-pin
Toshiba Satellite A665-11T, A665-12E, A665-12N, A665-12P, A665-12W, A665-12X, A665-13V, A665-13W, A665-147, A665-148, A665-149, A665-14C, A665-14D, A665-14F, A665-14N, A665-14Q, A665-14R, A665-15K, A665-15P, A665-162, A665D-S6075, A665D-S6076, A665D-S6084, A665D-S6091, A665D-S6096, A665-S6054, A665-S6057, A665-S6079, A665-S6080, A665-S6081, A665-S6088, A665-S6089, A665-S6090, A665-S6092, A665-SP6010L, A665-SP6011L, A665-SP6012L, C655D-S5044, C655D-S5046, C655D-S5085, C655D-S5087, C655D-S5133, C655D-S5234, C655D-S5536, C655D-SP5024L, C655-S5056, C655-SP5019L, C655-SP6001M, C655-SP6009L, L450-16U, L500-092, L500-1XR, L645-S4026GY, L645-S4026WH, L645-SP4025L, L655-105, L655-10F, L655-11W, L655-11Z, L655-13E, L655-13F, L655-13G, L655-13W, L655-14C, L655-14X, L655-16G, L655-16K, L655-16N, L655-16Q, L655-178, L655-17D, L655-17H, L655-17K, L655-17U, L655-17V, L655-17W, L655-1CC, L655-1CD, L655-1E5, L655-1E7, L655-1ED, L655-1EM, L655-1ET, L655-1EW, L655-1EX, L655-1F2, L655-1FN, L655-1G3, L655-1G6, L655-1K0, L655D-12P, L655D-134, L655D-13L, L655D-13M, L655D-13Q, L655D-144, L655D-S5050, L655D-S5066RD, L655D-S5076, L655D-S5076BN, L655D-S5076RD, L655D-S5102, L655D-S5102BN, L655D-S5102RD, L655D-S5102WH, L655D-S5110BN, L655D-S5110RD, L655D-S5110WH, L655D-SP6002L, L655-S5061, L655-S5062, L655-S5098, L655-S5098BN, L655-S5098RD, L655-S5098WH, L655-S5100, L655-S5100BK, L655-S5100BN, L655-S5100RD, L655-S5100WH, L655-S5106, L655-S5106BN, L655-S5106RD, L655-S5106WH, L655-S5112, L655-S5112BN, L655-S5112RD, L655-S5112WH, L675-00X, L675-01P, L675-01R, L675-06K, L675-076, L675-10R, L675-112, L675-11D, L675-11L, L675D-00V, L675D-S7014, L675D-S7015, L675D-S7040, L675D-S7040GY, L675D-S7047, L675D-S7049, L675D-S7060, L675-S7048, P500-0MP, P500-1D1, P500-1D6, P500-1DL, P500-1E1, P500-1E2, P500-1EQ, P500-1ET, P500-1F1, P500-1FX, P500-1GL, P500-1GN, P500-1GT, P500-1GW, P500-1H1, P500-1H9, P500-1HX, P500-1JD, P500-1JE, P500-1JJ, P500-BT2N23
