Kensington OfficeAssist Multi-Functional Copyholder
Quicklinx: G8QZWS00 Mfr#: K55910EU
The OfficeAssist Multi-Function Copyholder does the job of many, while using the space of just one. In addition to being a sturdy copyholder, it is a magnetic dry-wipe whiteboard, clipboard, book stand, mobile phone holder with built-in cable management for charging and pen holder. An ergonomic solution for holding hard copy documents, the OfficeAssist Multi-Function Copyholderhelps improve posture. It is the perfect desk-side companion, featuring 50-sheet capacity, dual page orientation and VESA compatibility.
  • Multiple desk items in one
    Saves space, while keeping you organized and comfortable.
  • Sturdy dual page orientation copyholder/clipboard/book stand
    Strong clip secures up to 50 sheets in portrait or landscape orientation, keeping printed materials comfortably elevated. Foldable legs hold thick books steady.
  • Magnetic dry-wipe whiteboard
    Easily write or attach notes, ideas, messages, whatever you can think of. Portable enough to take from room to room.
Kensington OfficeAssist Multi-Function - copy holder
Copy holder
White
Product Material
Stainless steel, high impact polystyrene (HIPS)
32.2 cm x 12.6 cm x 28.6 cm
815 g
Pen holder, integrated cable management, portrait / landscape mode, VESA interface support, integrated magnetic whiteboard, folding legs, max load 3 kg, smartphone holder, up to 50 sheets security clip
Copy holder
Product Material
32.2 cm
12.6 cm
28.6 cm
815 g
White
Limited warranty: - 2 years
10 °C
